ENDED - Arnova 10b G2 Resisitive - Finless Bob's "GingerComb" ROM Version 2.1 CWM BETA3
Thanks guys, so rvp2,your saying wipe the dalvik and then flash the beta3, see even after I followed bobs instructions to replace the callibrater app.my tablet still needs to be callibrated every time I turn it on, I truly believe I've got some type of hardware problem there.cause its always been weird.freaktab art developerif you like my work please buy me a pepsi
Yep Tattman65 try that. If that doesn't work you may have a problem. But, if it was fine before the update you shouldn't have a problem. If you do install 1.5 and see if you still have the problem.Only install roms with your battery charged fully.10b g2 2.1r. LG Optimus v cm10. Polaroid pmid4311 4.0.7. Flytouh 1.9. Craig tablet 2.2.
rvp2,its always acted kinda stupid from stock, from Bobs 1.4,1.5 roms so yeah I believe somethings wrong. But hey even if I have to callibrate each time no biggie 2.1 is agreat rom so I can deal with it. Thanks for your response though. I will try to wlpe dalvik and flash beta3.freaktab art developerif you like my work please buy me a pepsi
Originally posted by tattman65 View Postrvp2,its always acted kinda stupid from stock, from Bobs 1.4,1.5 roms so yeah I believe somethings wrong. But hey even if I have to callibrate each time no biggie 2.1 is agreat rom so I can deal with it. Thanks for your response though. I will try to wlpe dalvik and flash beta3.
BETA 3 will bust you after the first calibration unless you again go in and wipe cache and data. Not fun.
You my friend might have to stick with beta2 that allows you to bypass the lock screen with the volume button. OR go to beta 3 and install the buttom remapper and map the volume up to MENU yourself.
That shows your 3G connection. If you actually get a 3G USB stick, that icon will work.
Thus far, 2.1 is running very smoothly. I'd say a tad bit snappier than v1.5 even. The only question I have at this point is this: In Petrus' App Injector app, how do I access some of the system apps in the app drawer. I checked a few of them such as Picture Gallery 3D and stock video player, but I don't see them in the app drawer. I'm running ADW Launcher if that makes any difference.
I am discussing this with Petrus now. I have found out that if you install APPS before using APP Injector, APPs that are /system APPs do not get installed because /system has been remounted as READ ONLY!
My ROMs by default boot as /system being Read and Write. But if you install APPs first before using APP injector some apps will remount system as RO. A prime example is ES File explorer!
So what happened is you installed something that remounted system as RO, then you tried to use APP Injector and the APPs setup to be installed as /system APPs, did not get installed!
I am working with Petrus now to fix that bug. But if you want APP Injector to install them now, remount /system as RW then run APP Injector.
Another update guys.
I just found out why when you select ALL in APP Injector, some /system apps were not getting installed. The reason is I was not giving enough space to /system and it filled up. So the final ROM will have 300mb of system space which should be plenty for all APPs as well as stuff you guys may want to install there later.
I should have the final ROM out after you guys test for a few more days.
Can you boot up at all? You should be able to boot up with power plugged in?
arnova 10b g2 resisted been booted
Yes been booted for two days charging but when I unplug window says "Please connect charger battery is getting low 5%" It will then shut down.....Searching for answers and there are some with same prob after flashing new rom but suggestions don't work. They wan't original rom then send back to arcos. Can't find original rom for resisted..will keep playing around,
OK try this.
Boot into Clockwork. Go to advanced. Erase the battery stats!
If that does not work then boot up and using ES File Explorer setup for root and system as RW, go into
/data/system and delete the file batterystats.bin
Then do a FULL POWER OFF! Unplug the charger and boot up.
There are currently 1365 users online. 0 members and 1365 guests.
