Arnova 7G2 BETA is over!
This is my "launch" release!
If you want to read about the BETA testing go here:
http://www.freaktab.com/showthread.p...ion-2-1-BETA-2
This is the launch version.
The changes over the BETA are:
1) Added more space to /system for APP Injector and system APPS. This went from 240mb to 300mb.
2) Added the WPA_Supplicant from my 1.5 ROM which allows connection to ADHOC Wifi networks.
3) Updated to latest Superuser.apk
4) Updated the APP Injector package to the lastest updated Google APPs as of July 10, 2012
Everything below else applies.
________________________________________
Ok folks. With the success of my "Gingercomb" ROM for the 10G2, I am now releasing this same ROM for the
Arnova 7G2.
This is ONLY for the 7G2!!! NOT the 7b G2, etc!
Below is my stock description for Gingercomb and the download links below that.
2.1 is really my 2.0 with all of the fixes found to date and I have added Clockwork Mod. Now the testing of CWM was odd I must say. Most it worked for. Some had problems which I cannot repeat myself. It works for me 100%. Heck I can even flash 2.1 and restore 2.0 with no problems at all and visa versa.
Remember though. If you backup say 2.0 and flash 2.1 and try to restore 2.0, YOU WILL be back on 2.0 if you do a full restore! This is because it writes boot.img and system.img BACK! THis is in fact how CWM is suppose to work folks! If you want to try a "advanced" restore and restore your data and setting you can try it. Do an advanced restore and ONLY restore data and cache. If it does not work well... thats the way it goes! CWM is never a 100% gaurentee when you try to restore from different ROMs.
Now for those that dont want to use CWM.... Don't! It will not effect how the ROM works at all! Just on first boot after flash you will get the CWM menu. Select reboot now. DONE... you will never see CWM menu again unless you want to.
Want to know more about what CWM is? Read this:
http://www.addictivetips.com/mobile/...omplete-guide/
Also in the new APP Injector package is Petrus' reboot app. Install this if you want to reboot into recovery from the OS. Other apps wont do it for reasons I have gone into before. It's how Arnova decided to remove support for recovery from the kernel.
And more good news! I got permission from the maker of Button Savior! So that is now cooked into the ROM as a system app
OK for those that do not know what 2.0 is and want to know before flashing 2.1 which again is 2.0 with fixes and CWM, please read this post. In the link below there is also a link to a video showing you what my "GingerComb" rom is if you want to see it in action.
http://www.freaktab.com/showthread.p...OM-Version-2-0
Ok with all that said, here is the 2.1 CWM ROM Download link:
ROM -> Arnova 7G2 - "GingerComb" Finless 2.1 CWM ROM (215 megs)
Enjoy,
