0001: NEW CS968 T018 4.4 KitKat ROM Build UltraPackage Live Sports 24/7, Movies, Hottest TV Entertainment, Convic Tech XBMC Package Built IN, HBOgo, Vudu, World Soccer, Wondershare Player, Ace Stream Engine, SopCast, SubsLauncher, XfinityTVgo And UFC The Ultimate Multi-Media Super ROM Package Coming Today ...
UPDATE: The Ultimate UPDATE 6/7/2014 ...!
ShowBox and Video Mix Built IN {First Run Movies}
The New ShowBox and Video Mix Built IN {First Run Movies} Multi-Media Super ROM is now ready for download, {See Fast Download Links Below} ... Plus a ton and a truck load of all the Multi-Media Entertainment you will ever need all one Android TV Box {LibMedia.so Hack Ready} .... LIVE TV/SPORTS 24/7. World Cup Soccer App Built IN ....
GMail Tip:Update the GMail app, let this be the first thing you do and copy the GMail icon shortcut to your second slide apps screen, keep it there ... Doing it this way, the GMail icon will not disappear on reboots ...
DOWNLOADS:
*Get This ultimate MTK T018 Super ROM 2MPXX Version HERE
https://plus.google.com/communities/...artnerid=gplp0
*{Scroll Down to post number 0001, Click on READ MORE to expand the post, there you will find the fast Download link}
*ConVic Tech Playercorefactory.xml File DOWNLOAD:
*You can get the ConVic Tech "Playercorefactory.xml" file HERE http://www.mediafire.com/view/53yjv3...orefactory.xml ...
*PLEASE NOTE: ALL MY ROM BUILDS ARE USA BASED, MEANING YOU WILL BE USING A USA GOOGLE PLAY STORE (If You Are Using A VPN Set Up) All my multi-media apps are USA based ...! (NONE OF MY MULTI-MEDIA APPS ARE EUROPE BASED), Plus Your Android TV Box Will Not Run HOT Using The Above ROM Build ...!
The MTK T018 UltraTV1ONEPackage Has Been Upscale With NEW Multi-Media TV Apps
1.\ SonyWalkman.apk
2.\ Addblockplus.apk
3.\ Flashplayer.apk
4.\ Dolphin Browser.apk
5.\ YouTube.apk
6.\ MXPlayer.apk
The Dolphin Brower is not made the default browser, if you desire, you can still add the HTML5 NEW Google Chrome browser ...
Their is still a lot of diversity in this ROM build, you can go with the Convic Tech package {Built IN} or use the built IN Beyond XBMC v3.4 with the "LibMedia.so hack or use the XBMCZ with the Convic Tech package/LibMedia.so hack, your choice ...
This ROm build is now truly the ultimate multi-media super ROM "UltraTV1ONEpackage with a huge amount TV entertainment apps, plus speed and ultra high picture pixel crystal clear video resolution quality ...
The Ultra Multi-Media Super ROM Sports Package and Movies, TV Entertainment Package BUILT IN ...
1.\ The Ultra Multi-Media Super ROM Sports Package
A.\ WatchESPN Live Sports 24/7
B.\ World Cup Soccer {ESPN FC}
C.\ UFC {Wrestling, Prime Time Fights, Plus Pay-per-View Events} Performers: UFC - Ultimate Fighting Championship
2.\ The Ultra Multi-Media Super ROM Movies, TV Entertainment Package
A.\ HBOgo {TV Series and Episodes}
B.\ Xfinity TV Go {Basic Cable Package and On Demand Video/Movies}
C.\ Netflix {Movies, TV 24/7}
D.\ Vudu Movies and TV {Current Movie Release}
F.\ FilmOn Live TV {Live TV 24/7}
0001: NEW CS968 MTK OFFICIAL CUSTOM 4.4 KITKAT UltraPackage Super ROM
ENHANCED VIDEO RESOLUTION QUALITY, BUILT IN UPDATED NETFLIX, LIVE TV, AND NO BEYOND XBMC {THE CONVIC TECH XBMC PACKAGE IS NOW BUILT IN}
"See The Difference"
GO TO DISPLAY> SCREEN> HDMI MODE> AND SET YOUR BOX TO 1920x1080p-60 AND YOUR TV VIEWING EXPERIENCE SHOULD BE LIKE THE TOP PHOTO BELOW, {ALL MY ROM BUILDS HAVE ENHANCED PICTURE PIXEL CRYSTAL CLEAR VIDEO RESOLUTION}, NO 1080p HACK NEEDED, ENJOY ....!
DOWNLOAD:
*Get This ultimate MTK T018 Super ROM Version HERE
*{Scroll Down to post number {0001}, Click On READ MORE to expand the post, there you will find the fast Download link}
AC3 DTS PASS THROUGH VIA THE PLEX SERVER USING THE BUILT IN "BEYOND XBMC" V3.4:
AC3 DTS PASS THROUGH VIA THE PLEX SERVER USING THE BUILT IN "BEYOND XBMC": PLUS THE NEW ABOVE FEATURE{ABOVE PHOTO} MUST BE ACTIVATE VIA DISPLAY> OUTPUT INTERFACE USING HDMI .... {Sound Device Manager Must Be Set To RK29_RK1000 PASSTHROUGH}
AC3 DTS PASS THROUGH VIA THE PLEX SERVER:
Convic Tech Package Here: {This Can Only Be Activated Via This Package ONLY Using The MXPlayer {No Custom Codecs Required} ...
A awesome guide for setting up your Beyond XBMC or Gotham XBMC by Convic Tech https://www.youtube.com/watch?list=U...&v=0XrH1JVQb7w
I like this set up because you can have AC3 DTS with either your Beyond XBMC or Gotham XBMC ... It makes the MXPlayer the default player for local media files playback {No Custom Codecs Must Be Installed For AC3/DTS} ... It makes the Wondershare player the default XBMC DVD player {Use This Wondershare Player found here ONLY https://play.google.com/store/apps/d...ershare.player .... DO NOT USE THE WONDERSHARE PLAYER IN THE PACKAGE BELOW, IF YOU ARE USING A CR11S/CS968} ...
*PLEASE NOTE: The ONLY File You Will Need Out Of This Package Is the "Playcorefactory.xml" File, All The Other Apps Are Now Built Into The ROM BUILD http://www.mediafire.com/download/cd...13-14_Files.7z ... PLEASE NOTE: I'M THINKING EVERYBODY KNOWS HOW TO INSTALL THE
{Playercorefactory.xml FILE}
