Build date 09/05/14
This is for the CX-919 II tv stick model number CYX_809III_RK3188 V2_1 20140208 that can be found by opening the device and looking on the mainboard.
Netflix works great
XBMC works without issues.
You must un-install and re-install flash player to get it working without problems.
Use antutu overclock to set cpu to 1.43ghz and governor to performance Tick apply on boot box.
I am Getting just under 17000 score on antutu and it seems very snappy. I would suggest going into developer options and setting the window animation scales all to 0.5 or off to make it feel even snappier (I have them all set to off) especially animation duration scale. I would also suggest Nova launcher from playstore for a nicer launcher, or any other you may prefer.
Its running really well and so far I have had no problems at all.
Here is the rom :- http://www.mediafire.com/download/l9...om+factory.zip
Please do a full factory reset within android (THIS IS A MUST WITH THIS ROM) You will have problems if you don't! You have been warned.
If you need rooting instructions just ask.
