3Dlauncher apk
    3Dlauncher apk
    I'm looking for the the 3Dlauncher apk
    I'm trying to customize and tweak the gbox mx2 1.1.6 firmware.
    I see it in the apps section of my gbox mx2, but for the life of my i cannot find it in the system.
    i want to get a copy of the 3Dlauncher apk , so i can use it as a launcher option on another firmware I'm working on.
    where do i find it or can someone upload it here please
    ty
    ty
    Id say either the play store or a google search would be a more effective way of getting what you need As far as the legality of distributing someone elses launcher on your firmware I would ask the launcher developer...
    @µ$ł!Ω
      ty
      Here you go.
        the 3d launcher I'm referring to is the standard 3d launcher found in all the Chinese firmwares
        which Chinese apk developer do you think i should get permission from lol
        honestly I'm sure they don't care
        btw do you ask permission before viewing movies and all the other stuff in xbmc?
          Meltdown
          +1 Thanks
          Originally posted by Meltdown View Post
            oh if your talking about launcher3 that seems to be aosp. since its open source you should be legit to use in your firmware. make sure though. also there are many modded versions of that. some without that annoying google now searchbar super glued to the top of your screen. i would use that one...
            @µ$ł!Ω
              and by the way this is launcher2 which is a jelly bean launcher. your box should already have launcher3 on it...
              @µ$ł!Ω
                He said he's looking to edit the gbox mx2 1.1.6 firmware, which is Jelly Bean . . .
                  sorry my bad. Works kicking my ass and skimmed through
                  @µ$ł!Ω
                    Nowandlayda
                    +1 Thanks Button
