and installed beyond 3.4 like advised but all videos miss frames and the sound is slightly out of sync even running the cartoon hd app the videos are the same can anyone help me?
Help me I have cs918 on beyond 3.4 struggling at 720
I am new to this so please excuse me I bought this box http://www.amazon.co.uk/gp/product/9...?ie=UTF8&psc=1
and installed beyond 3.4 like advised but all videos miss frames and the sound is slightly out of sync even running the cartoon hd app the videos are the same can anyone help me?Tags: None
Originally posted by Tommya2004 View PostI am new to this so please excuse me I bought this box http://www.amazon.co.uk/gp/product/9...?ie=UTF8&psc=1
Your link isn't really helpful, because it is important to know which pcb/mainboard it use.
If you see, there exist so many different pcb/mainboard and often the stock rom isn't really useful.
To know, if and which custom rom maybe exist for this pcb/mainboard you have to open the case.
It is really easy... under the 4 rubber feed there exist 4 small screws... you have to use a small cross head screwdriver... than you can easily remove the top of the case...
Maybe make a picture off the pcb/mainboard AND give information about the WiFi chip (labeling)...RK3288 Devices
- Overview BOX (LINK !)
I agree with no_spam.. that would/could help.. to figure-out what/if there is a custom rom availble for your unit
-note there are about five cs918 units on the market.. the only way to id A unit.. is by opening the box
--the most common one.. see no_spams sign
But there could also be another solution..
Backing-up you current firmware..
-then using 'rkpatchomatic' to fix your vsync problem
Or
just gamble and install a custom fw.. (after making backup offcourse)
Wierd about the xbeyond.. normaly it should play 720 quite good
-perhaps, you could try SPMC
Goodluck
Here is my board can you help?
Originally posted by mitchell4you View PostI agree with no_spam.. that would/could help.. to figure-out what/if there is a custom rom availble for your unit
Or
Goodluck
Congratulation!
Your device use the K-RK3188-V4.3 pcb and looks like WITH bluetooth... (or not?)
=> if it uses bt than you can use:
B351_V2.0, K-RK3188-V3.5, K-RK3188-V4.2 and K-RK3188-V4.3 with bt (RTL8723AS https://aw-som.com/product_info.php?products_id=48) fit the same firmware by wasser http://www.freaktab.com/showthread.p...l=1#post176552RK3288 Devices
Bt
[QUOTE=no_spam_for_me;187078]Congratulation!
B351_V2.0, K-RK3188-V3.5, K-RK3188-V4.2 and K-RK3188-V4.3 with bt (RTL8723AS https://aw-som.com/product_info.php?products_id=48) fit the same firmware by wasser http://www.freaktab.com/showthread.p...l=1#post176552[/
how can I tell if it has bt
Originally posted by no_spam_for_me View Post... AND give information about the WiFi chip (labeling)...RK3288 Devices
Clueless
Originally posted by no_spam_for_me View PostIt is the chip next to the antenna cable and must be RTL8723AS https://aw-som.com/product_info.php?products_id=48
No, the quality is to bad... it is the blue module next to the antenna cable connector at the pcb... on the blue module there is a black chip... and we must know, what is printed on this black chip... I think it will be RTL8723AS (but not sure)...
Because of that, to find it easier at the pcb, I give you the link, but maybe this is, because of the labelling, better:
So if it looks like this picture, specially it is also printed with 'RTL8723AS', you can use wasser T-R42 FW at the link above...RK3288 Devices
Rom
Originally posted by no_spam_for_me View PostNo, the quality is to bad... it is the blue module next to the antenna cable connector at the pcb... on the blue module there is a black chip... and we must know, what is printed on this black chip... I think it will be RTL8723AS (but not sure)...
what T-R42 rom will I use B351_V2.0 or B351_V1.x ?
and it is '...new...'RK3288 Devices
Can you help me? Should i flash it with a new rom, or is there any other way? Root Checker gives "rk3188 rooted", but i can not find SU anywhere...
The details from the Android menu are: OS: Android 4.4.2, Kernel version 3.036+ Fri Dec 26 2014, Vendor software version: RK3188_R-BOX_ANDROID4.4.2-SDK
There are currently 2007 users online. 4 members and 2003 guests.
