i talked to logitech support and they gave me a compatible Android Box Code, called Measy B4A. I also learned all IR Codes manually and Logitech transform the RAW Codes in Binary codes. This works well, all commands are working .... but sometimes i get double commands, the cursor jumps two 2 apps or the ok button is pressed "2 times". The support changed all settings ( repeating codes from 0 to 3, 1 is maybe the best) with me, i tested but we found no solution. The original Remote works well.
Does anyone have a full working Harmony (i have a Touch version). I tried different ROMS from 102 to 104 ...
Best regards
Tim
