Upgrading firmware on a CS918 android box
    Hi all,
    I bought a quad core unthethered CS918 android box from ****. It comes with a load of addons and Beyond XBMC but doesn't seem very stable to me - its laggy and the screen flashes ever few minutes both in and out of XBMC. I only need Mashup and good HD movie playback. I was thinking of flashing the ROM from this post: http://www.freaktab.com/showthread.p...ing-works-fine. The box doesn't come with a cable that can connect to the OTG port - can I put the new firmware on a SD card and flash from there. If yes, how would I do that? Sorry for the basic questions.
    thanks
    1. are you sure your box use this pcb?
    If not => http://www.freaktab.com/showthread.p...l=1#post186517
    2. I think all rk3188 come without a cable USB to microUSB cable... but I advise to buy one...
    There exist a way, but it is really difficult (and I never try it):
    Update.zip via recovery menu from SD card - Modifier+Creator
    Hello,
    finally i found the tool that signs correctly all the zips i create
    and also the tool that helps to create the zip and the updater script, putting in it all the stuff i want (kernel.img, boot.img, and so on) to make a complete zip to be flashed via recovery menu from SD card, without the need of connection with pc, rkbatchtool, rkandroidtool and so on
    It is an XDA thread:
    My device find the zips created with these tools valid, so i can do any update i want
    I already tried a simple updater scripts that only prints some informations on the screen with ui_print
    Now i have only to learn the sintax of the updater script language, and to build the zip with all parts i need to recover my system...
    i created the updater script
    with four statements write raw image:
    for boot.img, kernel.img,misc.img,system.img
    (img extracted with a tool from the stock whole img)
    signed the zip,
    moved to sd card,
    applied update...
    and...
    Yeeeesss!!
    package_extract_file("boot.img", "/tmp/boot.img");
    write_raw_image("/tmp/boot.img", "boot");
    delete("/tmp/boot.img");
    ... and so on
    for the other three img (kernel,system,misc)
    RK3288 Devices
    - Overview BOX (LINK !)
      Thanks for your reply,
      I will get hold of the cable. I would be really grateful if you could look at my mainboard (below) and let me know what version I have got. Many thanks!
        You don't have a rk3188_box_szy_x6 ...
        => http://www.freaktab.com/showthread.p...l=1#post185540
        You have a K-RK3188-V4.3 BUT without bluetooth, so I don't have an idea which FW works for your pcb...
        => http://www.freaktab.com/showthread.p...l=1#post182381 till #70 ...
        RK3288 Devices
          Sounds bad!!! Is there any firmware I can experiment with?
            NO, both threads are talk about PCB with BT...
            RK3288 Devices
