XBMC A/V SYNC PROBLEM
    Can anyone help me fix the audio video sync problem on XBMC?
    My device:
    XMBC 14.0 ALPHA1
    MBOX S82 Amlogic S802 Quad-Core Cortex-A9 Android 4.4
    Model Number: s82
    Android Version: 4.4.2
    Build # 101k4
    CPU: Amlogic S802 Quad Core up to 2.0GHz (Cortex-A9)
    GPU: Octa core ARM Mali-450 GPU up to 600MHz
    RAM: DDR3 2GB
    ROM: Onboard eMMC Flash 8GB
    Please guys help me out! Thanks!
    it's not your device its XBMC, i had loads of audio sync problems on xbmc on android and PC (I5 4570, 8GB ram) you can select sound and change the sync or you can use a real media player like archos player. Once i installed archos player i never looked back. i always wondered why so many things were out of sync, turned out ther wern't it was XBMC putting them out of sync. Also all my stuttering went away the minute i stopped using XBMC
