Mbox M8 TV box Kitkat WIFI DNS settings
    Hi
    I was wondering if I may get some help, just bought a M8 android tv box running Kitkat 4.4. Is there a way to change the WIFI DNS address as I can't seems to be able to change it within Settings.
    Any help greatly appreciated.
    Found the solution!!!! It was darn easy hidden away in Android kitkat
    1.) Go to Settings
    2.) Press and hold the WIFI connection that is being use
    3.) A pop up window appears and select Modify Network
    The rest of the DNS settings can be change from pop up window, duh!!!!
      Originally posted by jonahky7 View Post
      Hi
      Or, after root. download one of many dns changing apps. (like setdns)
      @ยต$ł!Ω
        Thanks. I tried that before but only 1 DNS changing apps works, although flaky, with kitkat 4.4. The hidden method of changing was the easiest way. Although changing the DNS affects google's security certificate, but its fine for me as I don't buy anything via the android tv.
