HardwareGuru X5 with HLS streaming (04b)
    X5 rom with HLS Streaming
    It all started here:
    Karel made great effort to make a HLS enabbled rom based on my HWG HLS rom to suite the X5.
    See topic: http://www.freaktab.com/showthread.p...-HLS-streaming
    So i decided to build the rom for them.
    Included apps;
    MINIX XBMC
    MINIX METRO LAUNCHER
    SKYPE
    I left the keylayouts as karel put them.
    The complete X5 Rom that is HLS streaming enabled:
    http://xbmc.hardwareguru.nl/X5_HLS_04b2.zip
    Unzip it and flash the complete .img using rkFlashTool (not included)
    Wait till airpin starts up before you do anything !!!.
    You can flash your own kernels after completion, i left kernel outside boot.
    Have fun.
    Also credits to Karel for the good effort
    Must try this!
    Thanks HG
    Plasma: Panasonic TX-55ST60E
    HTPC: LC-Power 1320mi :: Sapphire PURE WHITE Fusion E350 :: 4GB DDR3 :: SSD Corsair Nova 2 [SO] :: 4TB [Storage] || Android PC: Minix X5
    powered by Win7 :: XBMC Gotham :: SABnzbd :: CouchPotato :: SickBeard
      Hi guru,
      Thx for your effort. This rom is also suitable for the x5 mini an g4 (108c) ?
      Thx KAR
      Verstuurd vanaf mijn ME173X met Tapatalk
        Originally posted by KAR View Post
        Hi guru,
        Thx KAR
        No not yet,
        I probably cover the other models next week when i work on the rk3066 guru roms again.
        There is still some things to do about HLS.
        I have planned 2 days next week to digg into this again.
        For now most HLS apps will work on the X5 with this rom.
          Re: HardwareGuru X5 with HLS streaming (04b)
          Originally posted by HardwareGuru View Post
          No not yet,
          Great Thx, hope the g4 108c will be covered as well
            Hey just to report same BT problems.
            Steps;
            1. completely factory reset my BT headset.
            2. paired headset with minix and i got to connect it (both media and phone audio) and no sound...
            3. BT kept restarting and headset connecting
            4. rebooted and headset paired but still no sound.
            5. sometimes connection is lost and bt restarts before BT connected.
            Logs:
            logcat.log
            dmseg.log
            Is it a kernel problem? system problem?
              Steps;
              Logs:
              logcat.log
              dmseg.log
              Its a system problem i think.
              This one was allready on my list for next update
              Thanks for the feedback.
                Yupp makes sense since every other file is from stock right?
                I've tried stock and kasty's rom and both work well with my headset.
                Thanks for your help.
                What libs control bluetooth ?!
                  Its probably not only the libraries.
                  Also some binaries etc..
                  I havent looked at it so cant tell you, they can diver from rom to rom.
                  At the moment i am working on the X8 rom so cant look at it right now.
                    stellar as alway bro! ill test tonight . i got x5 minis back let me know when you get ready.
                      No not yet,
                      Could you also have a look at miracast/wifidisplay?
                      When i connect my Nexus 4 it works for about 1 minute and then it suddenly stops. After reconnecting again it eorks for about 1 minute. Do you need a dmesg log?
                        Hi Guru,
                        In your initial update: "You can flash your own kernels after completion, i left kernel outside boot."
                        Does this mean the .img you have created does not include a full rom?
                        Sorry for asking noob Questions but need to make sure I install it correctly
                        Or do I have the complete package when installing your img and nothing else..?
                        Thx,.
                        KAR
                          is there a cwm version available?
                            No i dont need the dmesg, thanks for offering.
                            A new rom will be build next week.
                            Then the rom will be build from scratch again.
                            Hi Guru,
                            Thx,.
                            KAR
                            The rom includes a 720p original minix kernel.
                            It is a full package (.img)
                            You can flash a kernel afterwards, but you dont have to.
                            Originally posted by skazza View Post
                            Nope.
                            Hey mate, the other roms will be next week ( 05 with HLS )
                              Hi Guru,
                              With the version from karel I seems to missing the sleep timer. Does your version include the sleep timer?
                              KAR
