(Amlogic S802-H) Tronsmart Vega S89-H vs 4k Amlogic S802-H vs S82B
    Guys, i just wonder what are the differences between those 3, ive checked with sellers all were saying its the same HW all the same, but cheaper So have anyone some experience? What are the real differences?
    Tronsmart :
    4k:
    http://********.en.alibaba.com/produ..._1080p_4k.html
    S82B :
    Android devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
    Video Out: Benq W1000+ 1080p Projector
    Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
    Remote: Rikomagic MK702 II, Minix NEO M1
    Storage: NAS Zyxel NSA325v2
    RK3288 Devices
    - Overview BOX (LINK !)
      5 pices
      Don't talk about s802-H, talk about H.265...
      Don't talk about s802-H, talk about s802-B
      RK3288 Devices
        hmm so if i get it right...
        There 3 different CPUs:
        1) S802 no Dolby-Digital(AC3) or DTS hardware decoding
        2) S802-B (S802D) with Dolby-Digital(AC3) but not DTS hardware decoding
        3) S802-H (S802DD) with Dolby-Digital(AC3) and DTS hardware decoding
        There might be also an SW update possible, but ATM not much into on that...
        Anyway ive seen that you have Tronsmart
        S802-H and u ordered also Minix x8-H
        So just curious, is it worthy to pay more for the same HW? or how happy are you with the device or there are any good custom FWs out?
        Only reason why i want to switch for HW H version sound support, due to sound issues time to time during movies...
        I have Minix x7 atm. Thanks
          I'm nearly sure that hardware decode (downsize to stereo at a specialized CPU part) never will be enabled at s802 via software update...
          I only ordered Tronsmart and MINIX to compare both devices and have a look at the myth MINIX because of maybe better HW and maybe better software support, because at the past at rk3188 I often read the recommendation to/for MINIX (but I enjoy my K-R42 rev. 1(also working linux(kernel)))..
          RK3288 Devices
            ah i see...
            well i did the same with rk3188, first ive ordered RKM MK902 , but was sold out and delayed , so ive ordered also Minix x7 neo , i have both and basically when u find the good ROM that fits you , you have all the same anyway (except the extra CAM and MIC that RKM has).
            So now i would go for cheaper version...as i wont use Minix original ROM , but the modded one anyay - so the SW can be basically equal between those two.
              I think so too...
              First minix port is done by Finless and he will merge best of both together...
              But at rk3188, maybe because of all the different pcb's and the problem with the T, most devs stops to support them but minix x7...
              So, we will see
              (worst case in some weeks one of the both device will find a new owner via ****)...
              RK3288 Devices
                so in the end i took both as well
                260usd with shipping, even after research i came to the result that Tronsmart have many clone with different logos, but HW is the same ....but the price 99usd ive got for tronsmart was same as others had (diff. brands) for 16g version, but this guy had also Minix x8-h on stock so i took both. One one them goes to **** with Minix x7 + RKM MK902
                  5 Pieces ???
                  RK3288 Devices
                    no no 1pc each
                      got both last friday Tronsmart s89-h and minix x8-h
                      Seems like there is a still long way to go with FW updates
                        Re: (Amlogic S802-H) Tronsmart Vega S89-H vs 4k Amlogic S802-H vs S82B
                        heys killeriq,
                        indeed
                        im curious to hear what you think about both when you've had some time with them.. how would you compare? i also owned both boxes.
                        These are some things that i noticed more, and they kind of bothered me, but are not deal breakers.
                        when i order another (and maybe one for the folks), im trying to decide which one to get again because i had problems with my s89 reaching temps of 90+ deg c. but not everyone saw this.
                        yet my x8h runs a bit high but nothing like the s89 which spent most its time throttled to 800mhz
                        -i really like the look and build quality of the x8h and the tronsmart looks cheap to me and i dont like the roundness.
                        -the s89 got around 31000 antutu when it wasnt running hot.
                        -x8h gets around 22000 antutu
                        -xbmc is the same imo. save for better sound on x8h but no syncing problems for me
                        -loud pop through speakers when booting on x8h (annoying) but
                        nothing on s89
                        -neo m1 remote is a plus.
                        -better implemented sleep mode on x8h
                        these are things that are different to me that i can think of right now.
                        enjoy your boxes man!!! and thank these wonderful devs and contributors around here! i love Freaktab already. really cool and knowledgeable place
                          to be honest only difference ive realised and matters to me are:
                          750gb HDD external is working on s89 but not on x8h
                          s89 has only 2usb ports vs 3 on x8h
                          I just started s89 for 10mins and put it into box, post on **** to sell As u mention i also like more the minix style. But i guess the value is the same, hw too, just small differences. Actually i liked also the S89 remote more then minix, more buttons - but i havent tried it actually (will today )
                          I use RKM MK 702 II remote due to all those remotes are just useless as u need extra IR,Airmouse and keyboard, so its a bit pain to work that way.
                          Anyway i still got the X7, as main HTPC, X8H have update like every 2nd day, Beyond XMBC is not working on that yet...So im thinking i might sell X8h also and buy it later again in 2 months.
                          Because as it is now , both boxes are just like a toy to fix every day. During summer i dont have that much time to pay around with that, read the board all the time.
                          I thought that FW will be much better at least on X7 level
                            yeah good observation.. thanks for your input.
                            i havent heard of rkm mk 702. gonna look more into that guy.
                            also im interested in selling some things on ****.. i have 2 roku3's , an mx2, and some other junk. my first time selling on there but it should be easy, quick, and painless i hope. )
                            fyi: i have a 2tb toshiba external harddrive hooked to minix no problems. im even allowed to write to it now.
                              About the HDD, yeah seems like issue is only with that particular drive, strange that on Tronsmart is fine basically same FW/HW
                              The remote is also RT-MWK13 Wireless 2.4Ghz - http://www.riitek.com/product_Info.asp?id=92
                              Different names , but they are same, RKM is bit cheaper
