does someone here know how to deactive the remote controll via the console/terminal?
i know that you can do it using the settings app, but i dont have this app installed anymore (and dont want to have it).
i also found out that there is a config file located here 'system/etc/remote.conf' but i cant figure out how to disable the whole IR.
there is alos a bin file in 'system/bin/remotecfg' but this only prints out the config file.
thanks
