I tried so hard to find a way to root my Pipo Max M9 after the last upgrade firmware, from original Pipo support site, that was not rooted. Until now (even with the stock firmware) in every android device I had, I was making the root with "Unlock Root" software for windows with one click. At this time It was not possible to do the root via this software.
After a hard try I found the right and easy way to make my tablet be rooted without install other firmwares or custom roms as other solutions needed.
I post it at xda developers cause I trust it very much and it is the first place that I look to find solutions on my problems. I think that many users do the same.
The easiest and "clean" way is describing at:
blog .geekbuying . com / index.php/2013/03/14/how-to-root-rockchip-rk3188-quad-core-device-like-cube-u30gt-2-pipo-m9/#.Us_XzdJdUYs
(Delete the spaces. I done it that way cause I have not already post 10 posts to be accepted to present links)
Happy Rooting!
This work is not mine.
I re-posted here from Geek Gadgets Blog and from the post of Eric
All thanks to him that helped me too!
