my tablet is connected to the TV with a HDMI cable. Sporadically the signal on the tv will be "lost" resulting in a black screen for a second and then coming back while displaying the resolution on the left upper corner of the tv screen.
This can happen once every 5 minutes but also 2 - 3 times only with a few seconds interval.
Nothing is installed on the tablet, just the Rilley ROM, that's it. I tried 1.7, 2.0a, 2.1 etc and all the same problem. Also when I install Netflix and Hulu then when playing video I have this problem.
Also, I connect my tablet while just on the home screen and this same problem exists.
As you can imagine, this is very annoying while watching a movie.
I have a second M8 pro tablet and there I do not have the problem, at least not with RilleyROM 2.0a. I had a similar problem when installing RR ROM 2.1 but only once every 20 minutes or so. No that I'm running on 2.0a I do not have that problem anymore on the second M8.
Does anyone experienced the same problem and did you find a solution for that??
Cheers
