Any help much appreciated. Thanks
Minix X7 Mini
Originally posted by KRS View PostI have just got the above device and I cannot seem to get it to connect to my PC even after the drivers have been installed and also how do I put it into bootloader mode?
I am trying to install the drives on Win7, it comes up after the installation process and says that the drivers have been installed, but when I connect the device via USB to the computer it doesn't recognize it
Originally posted by KRS View PostI am trying to install the drives on Win7, it comes up after the installation process and says that the drivers have been installed, but when I connect the device via USB to the computer it doesn't recognize it
You can also verify your drivers are installed properly by using the driver tool Minix has on their website... when you run it.. have it uninstall the current drivers then have it re-install them. Try the other suggestion first since you may have the drivers installed right already... this is just a fall back suggestion/idea
There are currently 1210 users online. 0 members and 1210 guests.
