Official ICS 4.0.3 for Arnova 10G2
    Official ICS 4.0.3 for Arnova 10G2: http://arnovatech.com/support/update...hu&lang=en
    For Arnova 10G2 with official firmware:
    [SPOILER]How to update the software of your Arnova
    1. Download the update file for your device « update.img » or « update.zip ». You can save it to the desktop of your computer for example.
    2. Connect the USB cable to your Arnova and your computer so that the ARNOVA is seen as an external hard drive (as normal).
    3. Copy the « update.img » or « update.zip » to the root of the device. Do not place it into any folder of the Arnova, just to the root level of the device.
    4. Unplug your device safely as usual using the green « disconnect safely » arrow in the system tray.
    5. The Arnova will find the update automatically and display a message box offering to install this new firmware. Before tapping on "Install", you need to connect the charger/adapter DC-IN to your device. The Arnova will find the update automatically and display a message box offering to install this new firmware. Before tapping on "Install", make sure you connect the charger/adapter to the DC-IN of your device.
    Important warning: Upgrading your device's software will reset all your settings (including the WiFi settings).[/SPOILER]
    For Arnova 10G2 with custom firmware:
    3. Download Rockchip Batch Tool. User guide: http://www.arctablet.com/blog/featur...flashing-tool/
    4. You are done, let the tablet reboot and update itself.
    1. Root http://dfiles.ru/files/xzlpdq6vb . Restart.
    2. Google account with GAPPS Installer http://dfiles.ru/files/2ypinp8bp
    3. GAPPS for ICS 4.0.3 http://dfiles.ru/files/7izs1mlsa (install Root Explorer, copy files (not directory!) from this archive to similar tablet directory on /system . Restart.
    Quadrant: 1390
    AnTuTu: 3522
    Arnova 10 G2 & finless' 2.2b PRO
    Nice but!!
    Quadrant: 1390
    AnTuTu: 3522
    Installed this image but,
    32 Gb microsd is not seen by this rom, not in sd slot nor in a reader through usb.
    Strange thing is that using Finless v2.2 rom (gingercomb) sd card was not seen in slot but worked okay using a sd reader through usb.
    Is it possible to get this working again in tis rom?
    Using Kingston 32 Gb class 4 sd.
    Or will this rom see other 32 Gb cards using both ways?
    TIA, greetings from the Netherlands.
