URGENT! Bricked CX-919 ? PC does not detected it
    I have a CX-919, although I press the Function button and connect it to the pc (blue led is on), my pc does not detect it.
    I have another unit and don't have any problems with it (so the usb cable, drivers are o.k.)
    Is there any thing I could do?
    Is There a way to reset the unit with a sd card?
    I saw there is a way to reset the NAND chip will it help?
    this is my unit
    Does the NAND chip is marked with: "model: Flash: 8Gb DDR: 2Gb" ?
    What is the procedure for it?
    hold the flash button in before you plug it in. then unplug it, and try to plug it in again with the flash button held. I had the same issue and some combination worked.
      Tried it but it didn't work
      Any one tried to unbrick cx-919?
        Mask-Mode
        Had the same problem.
        Search the forum for cx-919 and mask mode or look at this link here:
        After some trries i finally get my cx-919 back to life and flashed this ROM, which works wonderful.
        But i must say, that i have an RK3188-T Model, V.1.1
