1.Support for DVB-S2 --By Taki
ATSC tuner supprot --By clarkss12
2.Design a wonderful Remote Control --By ENDRJUPL
--I think it should have multimedia buttons - volume up and down, play, pause, rewind, forward, stop. If it had buttons 0-9 they could be mapped to various live TV stations in xbmc which would be great.
Short press of the power off button - complete power off. Long press - 3 options appear: reboot, power off, standby
--By ENDRJUPL
--Perhaps a few ''programmable buttons'' on the unit..
Like:
when clicked.. it starts playing your favorite on-line radio channel (without the need of a tv running)
Or when the second button is clicked..it starts playing your Music collection
--By mitchell4you
--Hide(status)Bar on/off
Switch between running apps
--By mitchell4you
--Used in dim environments,Support HDMI CEC,Used by average size western male hands,A built-in MIC and Google Voice. --By wolfe
--Turn on/off Box using Remote
--By convict
3.Support HDMI and Spdif Passthrough sound output at the same time --By ENDRJUPL
4.Support VGA output --By raxy
--At this version,we can't add this feature.
5.Support to 3G DDR3 RAM --By endera
6.Support for HDMI CEC --By emdera
7.The following: --wow so many ideas
Boot manager
a easy recovery/backup method,like CWM?
A auto-shutdown/boot-up schudule option
Tun.ko pre-installed,for VPN
init.d support
Brightness control under settings
hidden developer section: with the option to ''Enable Root access'' with 'SuperSu'' install popup
A Big 'internal nand' Space.. say 3gb+ (space to install apps, not all apps support moving to sd)
A good wizard to set the lcd screen size/borders
A option to set a password on 'settings' (stop kids/friends messing with the settings)
On notication Bar:
Quick swap from wifi / lan Slider
Quick eject usb button*
Quick enable/disabe software keyboard Slider
Webcam (driver) on /off Slider*
( *= Only showing when device is connected)
--By mitchell4you
8.Removable and upgradable external WIFI antenna,and U.FL + SMA Connectors --By raxy and TMx
--Not support in this box,but we'll do our best for wifi signal performance.
9.Multicolor LED to indicate some status of the box --By raxy
10.HDMI input --By clarkss12
--No support for this in this version.
11.Some form of brightness and contrast control. --By Bob
12.mouse wheel zoom function in accessibility options --By Bob
13.A own gui launcher --By sweup
--This will be discussed after R89 coming stable.
14.OTA update --By ademturk
15.Popcorn Time --By JorgeO
16.automatic adjust display refresh rate (HDMI mode) to match video --By wasser
17.Multiuser --By wasser
18.Openelec and xbmc linux --By taki
I'll list all kinds of advice here to discuss.
--By ENDRJUPL
Like:
--By mitchell4you
--By mitchell4you
--By convict
Boot manager
init.d support
On notication Bar:
--By mitchell4you
