Howto.. flash w450
    Howto.. flash w450
    Goodmorning..
    I'm trying to upgrade my w450 with
    Good news ! W450 has the latest upgrade version stock 2014/03/02  firmware, Upgrade file and upgrade tool download link   : http://www.mediafire.com/download/nb7vzqvnn44p5rk/w450_3-2_XKFOv01.01b09.rar   Flash tool download address: http://www.mediafire.com/download/3d22tc222fck5x2/Flash%20Tool%20for%20%20NEW%20TS7%20SP_MDT_exe_v3.1344.00.00.rar   This upgrade […]
    Sadly..its not going well..
    Moborobe / phoenixtools see the phone..
    But the tool given on GK..does not
    nor SP_Flash_Tool_v5
    thoughts ?
    GK forgot to mention, disable Quick Boot first
    New fw installed / rooted /GPS fix applied..
    Let's see.. how it goes
    Cheers
      Now it says invalid imei...
      Xda says... Well known issue
      For changing IMEI just do following things
      1. Install "MTK Engineering Mode Start" App
      2. Then go to MTK Settings
      3. Go to Connectivity
      4. Go to CDS Information
      5. Go to Radio Information
      6. Select Phone1
      7. At the top there is a command line which begins “AT+” just type there “AT +EGMR=1,7,”IMEI_1″ (Put your first IMEI number, check phone box or case for imei)
      8. Hit send command and you will / may get a confirmation that "sent to mSend".
      9. Now go back and select “Phone2″ (for the second IMEI number)
      10. At the top there is a command line which begins “AT+” just type there “AT +EGMR=1,10,”IMEI_2″ (Put your second IMEI number)
      11. Reboot your phone and check you IMEI number (Dial *#06#).
      12. Enjoy.
      At command failed to send...
      Nice update GK..
      ---will try this tomorrow
      http://blog.geekbuying.com/index.php...xx-smartphone/
        Got a brainstorm the cmd should be
        Code:
        AT+EGMR=1,7,”IMEI_1″
        AT+EGMR=1,10,”IMEI_2″
        Imei_1 should be replaced with your imei code for sim1
        Imei_2 for sim2
        Mine stated 'msend' and after a reboot.. Back on the grid
        A simple..upgrade..costing just 5h of my life
        --mod oke.. Let's keep it here --
          This is useful stuff. Thanks for posting.
          Do you really want the thread deleting?
          Sent from my Nexus 7 using Tapatalk
          900Supersport
          freaktab developer
            Upgrade MTK phone
            lets see..
            *things you need
            Mtk driver ( under link )
            root tool ( i like Rootgenius )
            upgrade tool http://www.mediafire.com/download/3d...1344.00.00.rar
            firmware
            *Pre-install stuff
            -make a backup of-your-stuff -contacts/favor/...
            -Install MTK uncle tool from google-marked
            -make a backup of your installed apps
            -enable USB debugging under Settings/developer
            -Disable quick boot under settings
            -time to root your unit (like with Rootgenius)
            -time to use mtk uncle to make a backup of your imei code(s)
            --optional make a backup using titanium backup
            powerdown unit
            remove battery sims and sdcard
            *Install driver process..
            With the no battery.. connect pc to phone
            Open device manager
            now you need to be quick.. connect battery phone
            windows will detect MTK device.. quickly find this in device manager open it
            now install the MTK driver
            Like this
            I have been asked lot of time how to install USB drivers for lava iris 504q and other MTK 65xx devices. so here i am explaining Step by St...
            *Driver install Check process
            Remove cable then battery
            On your pc : start the upgrade tool
            Make the settings just like this picture:
            Hit the Start All button
            connect cable to phone / re-connect battery
            --If the driver is installed properly.. the upgrade tool will give a error popup
            Click popup away
            *Upgrade process
            Now.. wait 10sec and hit the Start-all-button again
            powerup your phone..(button) it should start-upgrading you phone
            *final steps
            if the upgrade is completed it should give Green with UserdataCrC oke (pic above)
            Close down upgrade tool
            Boot-up your phone
            First run give the phone 5 min to settle
            Enable Usb debuging
            Use the root tool..
            --shutdown phone : connected Sims/sdcard ect
            Power-up phone
            Restore the backuped apps / phone data..contacts..favor...
            Run MTK tool... give it root access.. restore IMEI code(S)
            Reboot..
            Final thought.. Un-install mtk uncle tool (even not used, it uses a lot of CPU/battery)
            Well.. everthing should be working
            Goodluck
            PS... The w450 is a great/cheap phone...well worth the money
            --bought mine from geekbuying on 'black Friday/Monday deals'
            There are custom ROMs here.. (Not tested by me)
            http://en.miui.com/forum.php?mod=vie...highlight=w450
              First bugs found
              1.Sound volume on FM-radio app... Is real low
              --tried volume+ app... But no dice
              2.Now I get warning msg... On poweramp/xbmc (but not on fm-radio)
              I never seen those msg's on the pre-installed fw
              The warning msg can be disabled using: (under settings)
              https://play.google.com/store/apps/d...volumev2&hl=en
              It seems.. (Will test this later...)
                Have you look at the engineer menu ?
                Tapatalked
                if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
                then mv $user.contact.up.post /.trash; set response($response.type = ignore);
                $user.up.post.ignore_in_future = true; fi;
