dump stock rom cs918
Try this:
I do not know if there is a separate thread with this tool, but I have found that it is the easiest one for me to use.
Post #61 has a Dump Tool, I feel like I link to it all of the time, because of questions like this one. I highly recommend it. It was created by abdul_pt. < Thank him.
So long as you can connect your device to the computer, install drivers, enable USB Debugging and let this tool do it's magic, it will pull off the essential elements needed for a factory reset.
Once you get those, plug in the second one, and flash the elements to that device. I think those came with either Allwinner or Rockchip so I don't know what you need to do that, except if it is a Rockchip device, use the RK flash tool v.1.37.Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
Originally posted by budgetgeek View PostI do not know if there is a separate thread with this tool, but I have found that it is the easiest one for me to use.
thanks for the reply......I found a rom finally that works with my box.. after puling the cover off ..sees my box has the same mother board numbers as the older cs918 ..rk3188_box_szy_x6
v1_0 131024 but has different Bluetooth and wifi chips also remote is different .......link to the stock rom that worked for me ..all same as my original rom just different bootup or splash screen ...link to rom for someone else with my problem https://www.dropbox.com/s/6hgc9gmfgj...box_140407.img thanks
There are currently 2112 users online. 0 members and 2112 guests.
