Current configuration
M5 Square Box/Quad Core AmLogic 450 /em8_Finless_rom16/xbmc 13.1 Gotham-armeabi-v7a
Supplied remote control works no issues
Bluetooth issues using following devices:
Mouse Desktop HP H3751-AA
AirMouse iPazzport KP810-16BAR
keyboard Logitech Bluetooth
Turn on M8 Android No Bluetooth Issues with these devices
load XBMC no BT access with any of the above devices for 1 to 2 minutes.
Desktop mouse access after 1 to two minutes erratic
AirMouse access after 1 to two minutes erratic
Keyboard access after 1 to two minutes erratic
Both mice will jump all over screen, almost impossible to control until settle down, typically 5 minutes if left alone.
Both mice once "settled down" able to click on individual icons/thumbnails or indivudual listings if in list mode, most of the time. Occasionally will motorboat and access each line or thumbnail at times lasting anywhere from 10 sec to a minute. Once in awhile necessary to turn off M8.
Keyboard pretty much same as above.
Only the M8 has exhibited this problem from the beginning using:
factory initial release Stock ROM
2014A_0414 (Geek Buying)
K200A_ap6330_03282014A_0516 Geek Buying
Finless_rom16
XBMC (.org only) frodo 12.3 through Gotham 13.1
These three Bluetooth devices work fine with the following:
Pivos/Xios
G Box Midnight
Tronsmart NX
Lenovo X-220
Lenovo Yoga 8
Amazon Kindle Fire HD 8.9
Anyone having success with Bluetooth or is this an issue with the Square M8?
