Android KitKat 4.4.2 firmware for MK809 II / UG007II Stick
    Maybe of interest to some of you. I haven't tried this yet so really cannot comment, flash at your own risk.
    http://chinagadgetsreviews.blogspot....-firmware.html
    Update:
    Well, it is KitKat but the BT or WIFI Radio doesn't work on my MK809II which is a JUSTOP K9B (MediaTek Chipset)
    Tried both versions of radio's provided within the link.
    Here's some rom info:
    Splash startup screen displays Android Logo and Smart Box.
    Vendor software version is: RK3066_R-BOX_ANDROID4.4-SDK_V1.0.0_20140310-BCM
    Build number is: rk3066=eng 4.4.2 KOT49H eng.hyz.20140516.111711 tesk-keys
    Kernel Version 3.0.36+ Fri May 16 11:17:01 CST 2014
    Display settings show all resolutions up to 1920x1080-60 although looks very much upscaled so doubt its a 1080p kernel.
    ROM is very stock with minimal standard apps apart from the addition of Flumpsters Beyond XBMC 3.4 preinstalled. No idea whether they sought his permission to preinstall with this ROM.
      Update:
      Well, it is KitKat but the BT or WIFI Radio doesn't work on my MK908II which is a JUSTOP K9B (Ralink8188)
      Is it getting stuck on boot or are certain devices like wifi not working?
      Cheers,
      JockyW
      EDIT: sorry I didn't read careful enough. Please ignore my question.
        Tried it too on my MK802IIIs - MTK, and yes, Wifi doesn't work.
        Now looking for possibility of using an USB Wifi dongle.
        Sent from my LG-D802 using Tapatalk
          very tempted to try this on my mk 809ii currently running bobs imito 1.7 rom,any one no if it works on the AP6210 Wi-Fi chip & is it stable
            Is anybody working on getting KitKat on the MK808 sticks? Hoping so...
              It interests me too.
              Maybe mo123 coud help...
                tested ap6210 on mk808...non b
                no wifi...i can deal
                no audio...deal breaker
                it is smooth as silk...we need to talk to this guy to release his code....works wonderfully.
                xbmc iss awesome goes full screen automagically. netflix works.
                will test some others i found tomorrow.
                  Hello guys, the rom appears to come from this site, http://ugoos.net/blog hopefully they'll fix the MediaTek radio issue as it has been mentioned by many people that the MTK version doesn't work.
                  Very annoying really as the rom seems to be pretty fluid. I have no USB to ethernet adapter so cannot fully test.
                  Sent from my GT-I9300 using Tapatalk
                    Should note the rom islisted in the download section of the ugoos site.
                      Anyone tried this? http://www.freaktab.com/showthread.p...642#post198642
                        Originally posted by Dabolx View Post
                        Yes, can confirm it does work on MK809II MTK chipset.
                        Special thanks to Shomari for providing the rom.
                        Cheers!
                          Nice looking clean fast rom. Rom isn't rooted. Tried rooting with kingo but fails.
                            Select UNROOT in Kingo; then select ROOT in second pass and it should work. Worked for me. Towelroot does not.
                              UPDATE! Use the ROM found by Shomari if you want a working KitKat solution for your RK3066 device. He has also compiled an overclocked kernel too, thanks Shomari!
                              Confirmed working on MediaTek Chipset on MK809II
