I have a couple of questions
    Hi Folks
    Is there anyway to get this to launch straight into xbmc................makes it easier for partner and secondly can a harmony remote work this in xbmc?
    Ooops sorry another one...if I update will I lose all my saved faves etc......sorry if this is such a noob question
    Many thanks
    Originally posted by aardvark View Post
    Hi Folks
    Many thanks
    About auto starting XBMC, this should do the trick: https://play.google.com/store/apps/d...=com.autostart
      Harmony
      RK3288 Devices
      - Overview BOX (LINK !)
        If you auto-launch XBMC ( or other app ).... make sure to have enough delay set on it so the internal SDCARD is mounted first before the app is launched or your user settings etc won't get loaded.
        If by fav's you mean your XMBC settings etc... backup your userdata folder onto an external SD card first. Usually the user data areas ( ie internal sdcard ) is formatted during a flash and any data there would be lost. The same goes for other apps data/info if they are saved there.
          FYI I use the XBMC add-on APP for backing up XBMC. Works great!
            Many Thanks to all above for the responses and tips, I managed to get the Harmony working after a fashion, couple of tweaks still to do
            Ta
              XBMC needs about 2min to start via Autostart...Why?
              Hello.
              Yesterday i tried also the Autostart-App.
              But it takes about 1-2min until XBMC is starting after the Bootsequenz of my Neo X8-H.
              Is it possible to force a quicker Start of XMBC?
              Greets from Germany
              Ingo
