HELP! M7 Pro Can't turn on WIFI
Pipo M7 Pro - wifi problem
Same problem with my tablet.
Can't turn wifi on.
It worked great for a few months.
A week ago the problem started.
I tried to flash the latest RileyROM, it didn't help.
I looked in the device logcat and saw an error when trying to turn on wifi0.
Do you have any idea what it could be?
Thank you.
log cat errors
These are the logs from logcat (relevant to wifi):
06-27 05:00:55.550 458-497/system_process E/RkWifiCtrl﹕ rk_wifi_load_driverrmmod)
06-27 05:00:55.550 458-497/system_process E/RkWifiCtrl﹕ rk_wifi_load_driver: open(/sys/class/rkwifi/driver) for write failed: No such file or directory (2)
06-27 05:01:01.410 576-576/? E/wpa_supplicant﹕ Could not set interface wlan0 flags (UP): Operation not permitted
06-27 05:01:01.410 576-576/? E/wpa_supplicant﹕ nl80211: Could not set interface 'wlan0' UP
06-27 05:01:01.410 576-576/? E/wpa_supplicant﹕ wlan0: Failed to initialize driver interface
06-27 05:01:07.300 458-497/system_process E/WifiHW﹕ Supplicant not running, cannot connect
06-27 05:01:10.300 458-497/system_process E/WifiHW﹕ Supplicant not running, cannot connect
06-27 05:01:11.300 458-497/system_process E/WifiHW﹕ Supplicant not running, cannot connect
06-27 05:01:11.300 458-497/system_process E/WifiMonitor﹕ startMonitoring(wlan0) failed!
06-27 05:01:11.300 458-497/system_process E/WifiStateMachine﹕ Failed to setup control channel, restart supplicant
06-27 05:01:11.300 458-497/system_process D/RkWifiCtrl﹕ Kernel version is 3.0.36.
06-27 05:01:11.500 458-497/system_process E/RkWifiCtrl﹕ rk_wifi_load_driverrmmod)
06-27 05:01:11.500 458-497/system_process E/RkWifiCtrl﹕ rk_wifi_load_driver: open(/sys/class/rkwifi/driver) for write failed: No such file or directory (2)
06-27 05
06-27 05:01:16.340 458-497/system_process E/WifiMonitor﹕ startMonitor called with unknown iface=wlan0
06-27 05:01:19.080 1282-1282/? E/wpa_supplicant﹕ Could not set interface wlan0 flags (UP): Operation not permitted
06-27 05:01:19.080 1282-1282/? E/wpa_supplicant﹕ nl80211: Could not set interface 'wlan0' UP
06-27 05:01:19.080 1282-1282/? E/wpa_supplicant﹕ wlan0: Failed to initialize driver interface
I have the same problem on M6Pro. Reseting to factory defaults didn't help. Neither the flashing of newer (KitKat) ROM. I suppose there is a HW problem with the wifi module, in my case the AP6476.
I am thinking about replacing this module. But first, could someone confirm, this is the reason, and replacing the module would help?
My second option is to connect some USB Wifi dongle via OTG cable. Does anybody have any positive experience with this? What dongle is confirmed to work on Riley's ROMs?
There are currently 2077 users online. 0 members and 2077 guests.
