update rom cable
    update rom cable
    i was wondering how to update if i was using laptop. the minix has otg port connect cable to it then the other side has different usb. how will i connect that wire other side to my laptop it wont fit into usb port,
    Which Minix, you have?
    A Minix X7 uses a non Standart Cable like this:
    Neomode
      x8h recieved today
      Neomode
        The USB cable supplied in the box is actually a micro USB to USB A cable (at least, that is what came in my box). The setup guide actually shows a USB A male to male cable as shown in the image in the above post.
