Bricked Tronsmart T428!
    Hey guys, I'm writing here because I was flashing to the latest finless ROM and as it was rebooting I thought it was done so I removed the USB cord. Apparently it wasn't done rebooting so it bricked on me! This must happen to a lot of people and I haven't found a single page anywhere on the net about how to unbrick a T428. I've seen pages for everything else except this one. Can anyone please tell me exactly how to unbrick a Tronsmart T428?
    Update: I managed to unbrick my T428 by opening it up and lifting the heatsink tape to reveal a chip. That chip will have a small black dot on it and that's where pin 1 is. I held a knife between pins 8 and 9 while plugging in a cord into the mini usb port. It worked! Then it was recognized by the rockchip batch tool in firmware upgrade mode (blue instead of green). So I simply loaded the only firmware upgrade I had to fix bluetooth problems. Afterwards I used the ROM flash tool to install finless ROM 4.4.2 and it worked. Then I reinstalled the firmware upgrades, which worked. So now it's working amazingly but the bluetooth keyboard I have sticks really bad with it. It's impossible to type using the T428 even though I can pair the keyboard with my Nexus 7 just fine without problems. I have a full wifi signal now too but yet I still can't load some videos. It's really annoying and I've come to the conclusion that the wifi and bluetooth really need work on the T428 but I'll keep experimenting. At least I got it back from the dead. Since there are no tutorials anywhere on the entire net on unbricking a T428 I figured this might be able to help someone else.
    The process of opening the T428 is tedious. You have to be careful not to rip it open. All you simply need to do is pry the metal sides off and then pry open the two halfs one side at a time little by little. The antenna is stuck to one side so you can't just pull it open. Once it's open the recovery button will come loose; put it aside for now. With the HDMI connector facing left and the heatsink underneath, lift up the heatsink tape on the right side to reveal a chip with a small black dot on it. The dot signifies pin 1. Now count down to pin 8 and 9 then hold something small like a knife between them while you plug in the mini usb cord, with the regular usb end already plugged into the computer. I held the knife down until I heard a sound signifying that the computer recognized it again. And thus it was saved! Put the heatsink tape back down and snap the halves together with the button back in the slot before you close them. Then the metal sides go on easily enough. You can smash them gently a little to make sure they stay on. So now that I have it working again I wish I could just improve the wifi and bluetooth reception greatly. Any ideas?
    Update: I'm learning of a way to extend wifi and bluetooth reception. You can find external antennas on Amazon ranging from cheap to expensive and they'll get the job done, as long as they have a usb connector. But since the T428 doesn't have enough usb ports with my wireless mouse receiver plugged into it I would also have to find a cheap hub with a few usb ports on it. This is for the diehards of course. The T428 was simply the predecessor to better ones coming out now like the Zero Devices Quattro. I'd rather have that one but I can't afford it so I'll probably just get a cheap external antenna and hub, but you have to make sure the antenna isn't hidden behind the t.v. screen. This is for android geeks really since it takes patience to deal with finding an external antenna to work with a bluetooth keyboard or mouse, and your wifi.
    Mine has been bricked for some time now and i've tried several times to fix it unsuccessfully. What firmware did you use in the batch tool? did you fully boot into that once completed or just go right about erasing the nand again and flashing finless?
    some more specifics on the exact process you used would be of great help to anyone else who has this issue. thanks for starting this thread!
      Firmware process
      Well the only process I followed was going into firmware mode after unbricking because it wouldn't let me do anything else. And the only firmware I had was the 1st one I tried. It wouldn't let me flash finless at that point because once I unbricked it it was automatically in firmware mode only for some reason.
        I believe that "mode" it goes into when shorting the pins is referred to as "mask ROM mode". What the actual purpose of that is, I don't know. Good that it's there though!
        Thanks to afterburner for this info. I know the same thing is applied to several different models of sticks and boxes but this also pertains to the T428 and the info on how to open it is nice to have available.
        I wonder if you could add a length of wire to the antenna wire that exists inside the T428. If you cut your wire to the same length as the original and solder it on and shrink wrap the joint. Is there a spot it could exit the case or a spot on the case where a small hole could be made?
        AND - here's a little video of doing it on another similar device:
        And a post here about mask rom mode from D3ZZ
        http://www.freaktab.com/showthread.p...ideo-Very-easy
        FLHT = Harley
        HEMI = 2010 Dodge Challenger SRT
        Cause I've been asked.
