The latest news about RK3288
Originally posted by gaetanolip View PostRK3288 Devices
- Overview BOX (LINK !)
Guest
Re: The latest news about RK3288
Originally posted by gaetanolip View PostTweaking?messing around? Are you able to download and install from playstore,for example,archos video player and its codecs?
If you don t, it is not a'out of the box' matter, it is only a problem of yours...Originally posted by no_spam_for_me View PostThat only describe the down-mix/-size process to 2.1 (stereo), but if you want to use path-trough, at rk3188 you need a patched lib...
Need I say more??
Hmzzz so tell me where to download a patched lib from Playstore.
hi,friend,this file is the install software,you can download it to upgrade it,if you have any questions,you can contact me.
this is
http://chinagadgetsreviews.blogspot....1_archive.html
Originally posted by wackidth View PostWhat's the worry??? I want a MEDIABOX XBMC with proper dolby/DTS sound out of the box. Without tweaking twerking and mess around with patches or codecs the reason why I said the X7 goodbye ....
A movie without dolby/DTS is a burger without meat.
So no Dolby licensed... It's a no go for a mediabox.
Keep in mind that the majority don't flash roms.
DTS is not available though...
RK3288 Devices
Originally posted by geekbuying View Postok, something i can confirm for the first bulk rk3288 device.
there is no dolby /dts hardware decoding right now, only can use XBMC to decode those file. so use the stock media player you won't hear any sound when you watch movies with dolby and dts. if the seller said it can do support dolby dts hardware decoding, fake.
No hdmi 2.0 right now. if there is any seller tell you that their device support hdmi 2.0,fake.
some model have the 1080p 24 hz, and 4K 24HZ support, some don't have,confirm it with your seller. at least tronsmart Orion R28 support 24hz, which is good for blue ray users.
i will test the passthrough later.
the CPU speed will at 1.6Ghz, and rock chip can't make it to 1.8Ghz or 2.0Ghz because of the high power dissipation, and the high temperature, if some seller tell you they have 1.8Ghz rk3288, fake.
Update: I might be wrong about the cpu speed, rock chip is still changing about this, but we can know high cpu speed, means high temperature, let's check what rock chip did when the real product.
rock chip just modify the pcba design last week, and if you receive the sample recently ,be careful, the real selling device will be different. now all of the factories are busy re-design the PCBA board, it's suck.
Eric
Actually we've got 4k@60hz working for a while already. I don't know why others can't . However, as I said there are new hardware changes required this week by RK, so this product is not ready for the market yet. I could see that RK really want to make it good before releasing to the market.
HDMI Bitstream (passthrough) is not working properly - only Dolby TrueHD is ok, all others are no-go at the moment.
First bulk??? It is impossible to be on selling now, old designs just got voided last week.Last edited by MINIX; 15 August 2014, 18:47.
Originally posted by encore2097 View PostAh looks like I was not clear.
RK3288 has a HDMI transmitter built into the SoC.
"HDMI2.0 to support maximum 4Kx2K display" [RK3288 SoC - Video Interface]
If the current versions of the RK3288 are not HDMI 2.0 capable, then will there be a new hardware revision later? That seems very expensive.
Alternatively, they could include a separate chip like on RK3188 boards.
If the RK3288 is already is HDMI 2.0 capable, then its a matter of updating firmware/driver support.
Originally posted by no_spam_for_me View PostTHX !!
... shit
Maybe they are going to sell v1.0 v1.1 v1.2...... again like the s802.
There are currently 1754 users online. 0 members and 1754 guests.
