Here is the instruction for how to change the ethernet MAC address in Tronsmart Vega S89 series. It should work on tronsmart vega s89 standard, s89 elite, and s89-h.
So why should i release this?
Some customers get several tronsmart vega s89 and use them in one home, they report those vega s89 can’t use at the same time, when one can get ethernet, the other are not. so it is caused by the same mac address problem, In this case, you should use the following method, and change the MAC address. but if you only have one tronsmart vega s89 in your hand, so you can pass this instruction, here we go:
1 Download the tools here:
http://www.mediafire.com/download/42inkc6v7j3ujng/Tronsmart_Vega_S89_Flash_MAC.rar
password: geekbuying.com
2 Decompress the file you just downloaded, and copy the folder ” License” to C:\Program Files(X86)\Amlogic \USB_buring_tool
If you can’t find this folder, you should install the usb burning tool first, check the instruction here:
http://blog.geekbuying.com/index.php/2014/04/08/how-to-update-firmware-on-tronsmart-vega-s89-amlogic-s802-quad-core-tv-box-should-work-for-all-amlogic-device/#.U5ldEig5WCA
3 Open USB_buring tools, and load the Key_523.img from your download file, and you will see this:
Make sure you load the correct img file, and make sure you choose the ” overwrite key” and then you should connect your Trosmart device with your pc. same like what you did in flashing firmware, and click Start.
This tool will direct give you newest mac address to the tronsmart vega s89.
Any questions, feel free to contact us.
Eric
Geekbuying
Source from: http://bit.ly/1q9JyMa
