software reboot to flash mode?
    Do we have an app for this? asking as one of my M8 units will not go into flash mode using the button behind the AV port - which is mighty annoying!
    Not that I can find. Our FreakTab reboot app wont do it either.
    it's a different command.
    However! I found a way.
    1) Have USB cable plugged into box a PC
    2) Use the upgrade APP in Android.
    3) Have some kind of ZIP file on sdcard. It does not have to be a valid update.zip
    4) Now when you use the upgrade APP and select the ZIP and click update, it will reboot and when it sees it is connected to a PC it wont go into recovery but will go into flash mode.
      What a star!!!!!
      Thankyou very much Bob! You are a star my friend - saves me a lot of hassle shipping it back for replacement!
