Please tell me what name is it? K-R42? or T-R42? or Clone?
    I buy it at
    http://www.****.com/itm/Hot-TV-BOX-m...item4ad6b56177
    What name is it? K-R42? or T-R42? or Clone? ... because it's cheap
    Thank You.
    It is a CS918 with AP6210 Chipset. Not bad overall.
    But I have a RK3188-T CPU.
    Neomode
      So,
      Did you win?
      Really cheap price.. (perhaps to cheap??)
      About your question..
      There are about 14 different versions of the T-r42
      -T-r42.. because the title on **** seems to indicate having blue-tooth
      And the all have the same box.. but differed pcb\motherboards inside
      So,
      ''Life is like a box of chocolates, you never know what you're gonna get''
      Cheers..
        After i get it in my hand,
        i will take picture to ask again.
        Thank you.
