M8 not going to sleep
    so nobody is having this issue but me? My M8 does not always go into standy mode when pressing the power button on the remote like it is supposed to. Half the time it works and half the time it doesn't. When it isn't working I try to kill all tasks and try it again but nothing happens. I tried using bobs reboot apps shutdown option but all that does is reboot the box instead of shutting down and it still doesn't go into standy after rebooting. I have to pull out the power cable to shut it off. If it doesn't go into standy and I keep it on for a while, I try it again hours later and all of a sudden it will go into standy 10 times in a row fine without me changing anything.. its so weird. This is getting very annoying and it also happens with my other M8. I'm using lifeforce rom. Anyone else having this problem?
    me too same problem.
