CS918 how to flash
    CS918 how to flash
    Just received the cs918, cannot flash it, please see attached pic of the vendor software as well as model #.
    Tried to flash it on my computer by holding the recovery button while powering, but will not work,even though was able to find and open it as a separate drive that is why I don't think I have a driver identification problem. Any idea of how to remove the cover without damaging the plastic?
    Please help.
    (Reset under the device)
    RK3288 Devices
    - Overview BOX (LINK !)
      Thanks for your reply, but I still cannot get my CS918 in the flash mode. When I hold the recovery button, nothing happens but as soon as I release that button than it goes into the drive mode and ask to open the folders, also it shows in device manager under Portable devices(RK31SDK). Could it be that my box is defective and wont go into flash mode?
        Your first problem, I don't know what's wrong, the device or your environment, because you can also press and release the reset during normal running and it will be immediately at boot loader mode ('Class for rockusb device' at device manger) and hold this state till you power off the device...
        Your picture isn't helpful, because no label information at the pcb and no information about wifi chip next to the antenna cable connector (of cause at the pcb)...
        RK3288 Devices
          Thanks for your help, but first I think my reset button is not working when pressed and released nothing happens.
          As for the PCB info, please see the attached, but no info showing on the wifi chip next to the antenna connector.
          Thanks ad appreciate the help
            I don't know, what's wrong with the reset...
            XT-Q7-V10 2013-12-05
            Of cause there is something printed at the chip at the blue "pcb"...
            Have a look at these threads
            RK3288 Devices
              Ok here are my specs, similar to the other post
              XT-Q7-V10, 2013-12-05
              WIFI; RTL8188EUS
              BT; Mediatek MT6622N
              So now, thanks to your help, I can find the FW, but still have the reset button not working!
              I have just received this unit, I guess I can file a complain that the recovery button is not flashing mode!
              Anyone else had similar reset problem?
                no_spam_for_me, could my problem be that I also own a Minix X7 and I installed the Neo Driver install o my computer?
                Do both X7 and Q7 use the same drivers?
                  I don't think so that this will be a problem...
                  but if ADB works, you also able to go to bootloader using adb:
                  adb reboot bootloader
                  RK3288 Devices
                    Any other method of flashing without the recovery button? Maybe through settings, etc,..
                      1. Setup android
                      I've these settings in android
                      Settings -> [DEVICE] USB -> Enable Connect to PC
                      Settings -> [PERSONAL] Security -> Enable Unknown Sources
                      Settings -> [SYSTEM] Developer options -> Enable USB debugging
                      1a. Unplug power
                      2. Install USB-Driver via Moborobo
                      2a. Connect device via micro-USB-cable at OTG-Port at the device with your PC
                      2b. Plug power to your device (starts up automatically)
                      (2c. uninstall Moborobo)
                      (if there are any problems try other way to install USB-Driver http://www.freaktab.com/showthread.p...l=1#post106326)
                      3. Download ADB
                      RK3288 Devices
                        Thanks, tried it (Moborobo) with no luck, but finally I got it in flash mode!
                        It was the button sensitivity tried few times, eventually worked
                        Thanks a lot.
                          CS918 how to flash
                          hello all i wud like to know how to get the driver file and rockchip batch tool
                          i have CS918 and the borad is ( XT-Q7-V11 2014-07-14 ) thank you
                            I never tried to connect my rk3188 since I use this drivers and tools
                            but it should also work with the rk3188 devices...
                            (because of the driver maybe also have a look at http://www.freaktab.com/showthread.p...-box-read-this!!!! )
                            RK3288 Devices
                              hi to all,
                              I flashed the new firmware and everything went ok,but its not booting up.its shows only red color in on/off button.How can I fix it?
