UPDATE 18-06-2014 (002Beta2) X8-H Flashable zip for NEO X8(H)
    LAST UPDATE: 30-06-2014
    PLEASE NOTE:
    This is a totaly different way of flashing and for that reason i ASK you to PLEASE keep bugs in this thread so MINIX can seporate the used firmware.
    Make sure you have a USB keyboard plugged in or you will not be able to use the menu.
    Also this will not work if the OTG cable is connected, plese remove it first.
    How to flash:
    1. download firmware zipfile.
    2. DO NOT UNZIP!, the zipfile IS the update package!
    3. format a sdcard or usbstick to FAT32 ( NTFS formated drives dont work )
    4. Put the .zip file on the root of the sdcard or usbstick.
    5. Power off the MINIX
    6. Insert the sdcard or usbstick. ( dont use the side USB, allways use the back USB port )
    7. press the restore button with a pin ( insert in the recovery hole on the back ) and KEEP it pressed.
    8. Press the powerbuttin and keep it pressed till you see the boot logo, then let go
    9. let go of the restore button
    You will see a menu:
    1. Select : apply update from EXT ( using your keyboard cursor )
    2. Select : Update from Sdcard / Update from udisk << usbstick
    3. Select the .zip file
    4. hit enter and wait till its done.
    When it is done select reboot and hit enter.
    All done!!
    PLEASE KEEP BUGS HERE on this topic !!
    If there would be a bug that is caused by the way this is made and flashed i dont want MINIX to get false info on the official firmware topic.
    Updated 30-06-2014:
    MINIX NEO X8/X8-H 002beta3 4.4.2 firmware
    Release Date: 2014-06-28
    HardwareGuru zip version: 2.0
    Change log:
    Update 002Beta:
    1.) Native Android virtual keyboard bug fix;
    2.) Fixed Aututu auto exit issue;
    3.) Fixed XBMC displaying with 1/4 screen size while playing 4K videos;
    4.) Ethernet MAC address information added;
    5.) Preloaded CloudTV app.;
    6.) Improved SONY 4K TV HDMI compatibility;
    7.) DVI-type signal output enabled for older TVs and monitors;
    8.) Added NEO A2 gyromouse key layout profile;
    9.) MINIX edition XBMC updated to version 13.1, support real 4K video output;
    10.) Preloaded Sopcast app;
    10.) Bug fixes of MINIX Metro launcher, weather info. service is now unlimited;
    11.) Various bug fixes of user interface;
    Update 002Beta2: ( 16-06-2014 )
    1.) Deep sleep mode enabled, system idle power down to 0.25W;
    2.) Added 1080p@24Hz mode; (Amlogic still haven't perfect it, treat it as experimental at the moment please)
    2.) Full screen app. running enabled;
    Update 002Beta3: ( 28-06-2014 )
    1.) Added XBOX controller support; (PS3 support coming on next update);
    2.) Removed lock screen when using VPN;
    3.) Fixed non-USB audio setting lost after reboot issue;
    4.) Added keyboard layouts of NEO X7;
    5.) Increased TCP buffer (credit to Finless @ freaktab.com);
    6.) Removed SPDIF auto-standby feature; (experimental)
    7.) Support NTFS write;
    8.) Fixed filebrowser return key (direct-exit when pressing back button) bug;
    9.) Updated preloaded app. version;
    10.) Fixed HDMI audio has output when using SPDIF passthrough issue;
    11.) Fixed OTA panel message error;
    12.) Fixed IR remote can't select default launcher issue;
    X8(h) firmware 002Beta3 - Factory Reset
    ( Niet voor HardwareGuru Klanten, U raakt GuruXBMC kwijt !! )
    - A Full factory reset with default preloaded apps from minix.
    X8(h) firmware 002Beta3 - Keep Data
    ( Ook voor HardwareGuru Klanten met behoud van GuruXBMC )
    - This keeps al your data and apps, Preloaded apps will remain, they will not be overwritten.
    Have Fun
    Gisteren de X8(h) firmware 002Beta2 - Keep Data er op gezet. Met deze beschrijving gaat het snel en perfect. Daarnaast werkt software ook goed. Mij vallen 2 zaken op: de aan/uit knop op de Neo A1 werkt niet en door de deepsleep mode kan ik de Neo X8 niet meer op afstand met mijn Logitec K400 aanzetten als ik deze in sleep mode heb gezet.
      NL; Hallo Pano, we zijn druk bezig de bugs eruit te krijgen.
      Dit is vooralsnog een beta met keine wijzigingen,Het doel is dan ook om feedback te krijgen van de gebruikers. Bedankt voor de feedback
      Hopelijk komt de de officiele release binnen een week of twee.
      ENG; Hello Pano, we are bussy to fix the bugs.
      This is still a beta with small adjustments to get userfeedback, Thanks for the feedback.
      Probably an official release come within 2 weeks.
        Finless now has xbox pad support
        Thanks for the current support with my new X8.
        Cant wait for the next updates, you zipped format is so much easier.
        1 question, Do I need to chose between your Rom and Finless Bob's for Xbox pad support.
        Your rom has 1080p 24hz
        He has just updated his with XBOX/PS3 controller support.
        I would rather stick with yours, but will you be able to build in the same controller support in the new update.
        Please keep up the amazing support!
        JOn
          JOn
          Hello Tannajona,
          Maybe soon, but next rom will probably be there in 2 weeks so you have to be patiant.
          I cant garauntee this support as i am lately into bug fixing mode lol and try to keep close to stock rom.
          Best regards,
          HWG
            No Probs, Thanks for the quick reply...
            Your ROM is currently alot more important!
            Just fancied an awesome XBMC / Torrent stream controller experience
            AND
            an Game emulator powerhouse!
            Keep up the sterling work.
            J
              My XBMC video playback is haywire after updating using this ROM. My video playback are all zoomed in, I don't know how to restore the video to proper view. No video playback issues via VLC or MX Player. Any solution for this issue? Appreciate your help and guide.
              The HBO is supposed to be in the center.
                Wich update did you use? Havent heard this before :S
                Verstuurd vanaf mijn T5 met Tapatalk
                  Dear Guru,
                  is the support for PS3 and Xbox360 wireless controller also an option for your costom 24p ROM or for the forthcoming stock ROM? This would be a great step to a media player allrounder.
                  I am looking forward as well to 23,976 fps, HD-Audio & 3D frame packed support out of the box.
                  Thanks a lot for your support and enthusiasm.
                    Originally posted by Skylinebasser View Post
                    Dear Guru,
                    At the moment i am trying to iron out the HLS streaming for rockchip boxes, after that i will continue the X8 (AMlogic) platform.
                    Maybe that will be an option soon, i am waiting for minix now to provide me with some needed things.
                    I dont know yet if HD audio will be an option soon, but again... its waiting for sources now.
                    I know init.d must be working first for the controllers to work properly from the mainline firmware.
                    Time will tell, as i sayed i try to be close to stock to improve the firmware.
                    It has to be seen if that is a smart thing to do but i think its best to improve things at the base then build aditional features on top of it.
                    HWG
                      I used this http://xbmc.hardwareguru.nl/X8-v1.8-...-KeepData2.zip
                      Maybe I will try the flashing with the factory reset firmware instead.
                      UPDATE
                      I reinstalled XBMC MINIX from MINIX official downloads and my video playback has been restored.
                        Today investigated the CPU of the MX8.
                        The CPU only works with 2 CPU's at a max of 1608 mhz.
                        I have tried CPU-Z, CPU-monitor and System tuner and loaded several games.
                        Is there something wrong or is this a firmware issue?
                        Made an other test with CPU monitor and Antutu. CPU monitor is reporting 4 cores and an initial speed at 2 ghz.
                        So there is nothing wrong.
                          Most apps dont read the cpu right. Did you use cpu master?
                            Just FYI:
                            While the rom contains the browser.apk (I checked, its there), it does not add it to the OS when installed. Your previous rom (6/15) did not have this issue. Just a heads up.
                              Originally posted by zektor View Post
                              Just FYI:
                              Thanks, i dont think it compiled well, i added bookmarks
