Hidden statusbar on x8-h
    Anybody know how to enable it (the top statusbar) always? It'd seems to be disabled by default. I don't have it hidden in the settings but it seems MINIX disables it anyway unless you swipe down from the top.
    Well, I like to have my clock at the top all the time except for when I'm in fullscreen apps so I'm trying to enable this. Could there be a build prop edit that could achieve this?
    Tha navigation bar on the bottom will stay visible when I want and, hide when I need it to, but not status bar.. It stays hidden.
    Thanks for any incite on this issue.. Other than that, x8h is doing pretty well for me. I'm on finless1.0 with KO tweaks and I'm using nova prime launcher (which isn't an issue) but I've tried worth the stock launchers as well
    as you can see from the pics, i like to use this device as an android first and foremost so i have all my widgets shown in nova but im missing my statusbar.
    here i tried to untick the 'show notification bar' in nova 'look and feel' settings. but it only drops the top google search bar a bit but the status bar never shows up.
    Update: I've looked through the build prop and I found these lines...
    ro.statusbar.widget
    false
    ro.statusbar.button
    False
    and the most interesting..
    persist.sys.hideStatusbar
    false
    so I changed them (AND THE SETTINGS STUCK) and rebooted but it didn't give me back my statusbar.
    Sent from my SM-N9005
    Re: Hidden statusbar on x8-h
    guess ill just use float clock for now. at least i can configure it and make it disappear and reappear on click
    ☆sent from a finless bob rom powered MINIX X8h android tvbox w/tapatalk☆
      What is this widget please ?
      Thank you.
        Thank you.
        that'd be dash clock dudey. there are many many plug ins for it as well in play store :thumbup:
        Sent from my SM-N9005 using Tapatalk
          Good ol' DashWidgets!
            indeedy!
            Sent from my NEO-X8 using Tapatalk
              Wow nice homescreen setup!
              I definitely should use Nova too, it's the best launcher and most configurable launcher out there.
              Is this comfortable to use with IR remote arrows? (i don't have an air mouse, i have S89 Vega Elite)
              Sorry for my bad english
              Tronsmart Vega S89 Elite | Finless Rom 1.7 | Searching for a good air mouse.
                Thanksya!
                This launcher isnt very easy to use with the remote arrows.but it can be done. I use a bt mouse and the logitech k400r. Sometimes I use Able remote from my note 3. I really only use my neo m1 airmouse (which has arrows too) while playing media (audio and video apps) like xbmc, Spotify, my cloudplayer etc
                  Thanksya!
                  Woha, Able remote seems awesome, later i try that.
                  I'm looking to buy a cheap (max 20-25 euro) and multi function mouse (air mouse, full keyboard, gyroscope, microphone) but the only one good is the Minix Neo A2, but i think it's not working on my setup because isn't Minix.
                  And yeah, Logitech K400r is the best keyboard/mouse bundle but it's too big for my "remote's table".
                  Thanks to you, now, i'm using nova launcher too and it's almost perfect, maybe from my sofa the text is too small. What are your Grid Sizes?
                    ro.statusbar.widget
                    false
                    ro.statusbar.button
                    False
                    false
                    Hello Cuezaireekaa,
                    I've got the same issue with the navigation bar, I saw it briefly one time but I don't know how have it... Did you find a solution ?
                      No solution to the OP sorry.
                      swiping in to see the statusbar and navbar, that's the only way
                        tablet mode
                        sorry for the noob question. but how do you manage to get the tablet ui to show on nova launcher? is it something that you get from the third party rom?
                          hit menu when in nova and enter nova settings. in there there you can configure it anyway you want. just make sure to turn on rotation in landscape
                            tried but no dice. think it's a limitation from stock rom. will flash custom rom when the next version is ready. thanks. and really nice setup you have there.
                              thansks a lot. i think it could be because i use the prime version which is paid.
                              apex is a good alternative too.
                              @cherokee my grid is 8x11
                              heres how i get my morning news, musics, and media into my veins.. through the bigscreen not meh phone.
                              android pro widgets
                              flipboard widget
                              media utilities
                              gonemad player for music on ext 2tb
                              my cloudplayer for soundcloud jukies
                              spotify
                              dash clock widget
                              greader
                              taptu reader
                              muzei live wallpaper running 500firepaper
                              nox icons
                              sorry for the horrible quality tapatalk uploads...
                              i think im gonna open a screenshot thread in off topic since we have a screenshot button on our navbar. just dont know if it'll get anyone to participate. plus most folks prolly use the default minix launcher which wouldnt be no fun in a screenie thread now would it
