the function of Cozyswan S400
    Cozyswan S400 rk3188 quad core Cortex-A9 processor with up to 1.8GHz speed,2gb ram 8gb rom:
    1. remote control by smart phones
    After upgraded into android 4.2 OS, S400 now enables the function that remoted by smart phones. Ur phone is now the remote control for S400! Regardless of age, sex, anybody are able to use this without easily! You are able to type in things by operating the touch panel of smart phones without sitting besides the TV and S400, and use the phone as a game pad. what is more, if the phone has built-in gyroscope, congratulations! u can play motion sensing games by using your phone and S400!
    2. Support DLNA, enabling sharing of digital media between multimedia devices
    The Digital Living Network Alliance (DLNA) is a non-profit collaborative trade organization established in June 2003, that is responsible for defining interoperability guidelines to enable sharing of digital media between multimedia devices.It is quite the same with Airplay. After upgrading, S400 now comes with built-in Ehome system, which support DLNA,allowing wireless display. You can share movies, YouTube videos, and anything that’s on your screen on your TV!
    3. World premiere android mini pc which supports Miracast.
    Miracast is a peer-to-peer wireless screencast standard formed via Wi-Fi Direct connections. UNlike the DLNA, Miracast supports mirrorring function, which means display the screen of smart phone on the HD TV. S400 is the first android mini pc which supports Miracast! All you have to do is open the wifidisplay function in setting. and then ,enjoy it!
    4. 10% performances enhancements of android 4.2 OS
    The upgrade of S400 has greatly optimized the performance of product. It operates more smoothly than before!
    5.malicious apps scan function, stronly secure your device!
    Android 4.2 integrated a unique and high-powered security feature into the platform that scans for malicious or potentially harmful codes in apps that are loaded onto a user’s device. With the feature enabled, if you try to install an app that Google has blacklisted, the install will fail. And this will definitely protect the System of S400!
    there isn't anyone has the question?
