M8 pro soft buttons very dim / almost invisible
    starting from RileyROM release 2.0a it seems that the soft buttons "back" "home" "history" are a lot dimmer then the "volume" soft buttons. I found that even in release 1.7 these buttons where already quite dim but now it's even more so except the volume buttons. Is there anyway to increase the brightness of these soft buttons because when outside it's very very hard to see them, if at all. Using rRom 2.0a
    no one any idea how to fix this??
      Haven't seen that one before. Is it like that from start (right after flashing) One app could be causing this. If not, I've heard of app that can set brightness: adjbrightness app
      Give it a try
        Thanks for the tip.
        Unfortunately it doesn't really have the functionality to increase the back light of the soft keys.
        Didn't anyone else notice the difference between volume soft keys and the other soft keys(home, ...)?
        Cheers
