.gif)
Below the latest super firmware for the Minix Neo X7:
Kitkat v 4.4.2 together with XBMC Gotham v13.1 ; the best of FW.
I have tested it all on 2 different Minix Neo X7 units.
#341
The new version Minix X7 4.4.2 Miracle 1.1 http://goo.gl/1sVlGo
genny, May 12, 201
#513
- Download Miracle rom v1.1 rar file
- Connect the Neo X7 (OTG port) to your PC using the long OTG-USB cable,
- Just put your Neo x7 in flash Mode (with a paper click press “res” hole,
keep hold down and press “Power” button;
your PC must detect the “rockchip USB device”;
release the “res” hole and the power button.
Then quickly pass to the next step,
- From Miracle v 1.1 package, run the RKAndroidTool.exe (file size547 kb) in Win7 always run the file as “administrator”;
it´s the RKAndroidTool v 1.37 & Loader v 2.10;
the first 7 lineas are selected:
1. Loader –
2. parameter –
3. misc –
4. kernel –
5. boot –
6. recovery –
7. system ;
the last line 8. backup, must be not selected, leave it like that.
I advice you only use the RKAndroidTool.exe (file size547 kb) v 1.37 from inside the Miracle v1.1 package,
as well preserve the directory/subdirectory/files structure when you uncompress the package.
- Then and finally just simply press “RUN”, nothing else, and let the program flash the rom,
it´s very fast, around 2 or 3 minutes to flash the rom, and other aprox. 3 minutes booting;
don´t touch the device during the proccess;
I always monitor the proccess having connected the HDMI cable to the TV to can see the first boot,
first start to be sure the proccess had been completed succesfully.
#242 and #501
To summarize:
last kernel 720p: http://goo.gl/yboCKI
last kernel 1080p http://goo.gl/QDTd3K
original rom: http://goo.gl/QFbWNu
settings.apk for correct usb-otg: (consider only the settings.apk) http://goo.gl/XERsUp
Download your kernel, swap the kernel in the original rom folder. Flash the rom.
After the flash, copy the settings.apk in /system/priv-app restart.
#242
