Once considered a novelty, 8-inch Windows tablets are now everywhere: Lenovo has two; Acer has two, Dell has one, so does Toshiba. Not to be left out, Some Chinese manufacturers recently started shipping their own 8-inch Windows tablet.
For
Good battery life
Nice display
Solid design and build quality
Full desktop functionalities
HDMI support
MicroSD card support
Sensible price
Against
Slightly sluggish performance with heavier applications
Poor cameras
Small internal storage
BOTTOM LINE
The Acube iWork 8 may not stand out in any one area, but it is a small Windows tablet with a solid design, a pleasant display and long battery life.
Key Features
8-inch IPS capacitive touchscreen of 1280 x 800 px resolution;
1.8GHZ Intel Atom Bay-Trail-T Z3735E Quad-core Processor, Intel HD Graphic (Gen7) GPU
1GB of LPDDR3 RAM
Windows 8.1
16GB of SSD built-in Storage
2MP front-facing camera/2MP rear-facing camera
Back-mounted stereo speakers
Wi-Fi 802.11
Bluetooth v4.0
USB 2.0 host (dongle required)
Micro SD card slot
Standard 3.5 mm audio jack
HDMI V1.4
5,000mAh Li-Po battery
The Cube iWork 8 an 8-inch, Windows 8.1 tablet joining the not so great but insanely priced Ramos i8pro and the more impressive Dell Venue Pro 8 as a place where you can get all the benefits of a full Windows PC like access to Microsoft Office and the ability to download desktop applications all in a much smaller, compact body.
As a member of the second generation of 8-inch Windows 8 tablet line, it is definitely thinner and lighter, yet still dogged by some minor performance issues.
Looks aren't everything. But to the extent that good design and build quality matter (especially on budget devices like these), Cube is off to a fine start. Unlike most of its rivals, the iWork 8 is more designed for horizontal use, you could tell that from its boot screen and also the logo placement on its back. It makes sense because most of the applications are made for landscape mode. But whenever you want to use it in portrait, the small bezel really helps you to have a solid hold.
You'll be hard-pressed to find an 8-inch tablet that isn't thin, light and easy to hold in one hand. Nonetheless, all that's true of the Cube iWork 8: measuring at 206*126*10mm, it immediately makes a good case for choosing an 8-inch tablet over a 10- or 11-inch one. The small bezel makes it look even more compact than the Dell Venue 8 pro and the Acer Iconia W4. Weighing at only 340g, it is even lighter than my first 7-inch Galaxy Tab.
One thing that makes the iWork 8 a bit strange to use at first: It appears to be missing a Start button. More precisely, it has one; it's just not where you'd expect it to be. Instead of a touch-sensitive Start button built into one of the bezels, the tablet has a physical Start key located on the top horizontal edge of the device, right next to the volume rocker. I'll be honest, it took me quite a little while to stop tapping the bezels and go straight for the physical button. That said, now that I've gotten the hang of it, I have to give Cube credit for at least choosing the button location carefully. Since the key sits on the top edge, over toward the left, it's easy to hit when you're using the tablet in landscape mode, and also when you flip it over into portrait, at which point the button is within reach of your right thumb. Still, a capacitive key would've been even easier.
The power/standby key and all the ports and slots are hosted on the left edge, you will find the 2.5mm DC port, a 3.5mm audio jack, a MicroSD card slot which you will surely need to compensate the small 16GB internal storage, as well as a Mini HDMI port. I am so glad that Cube includes the HDMI output for the iWork 8, which neither Lenovo Miix 2 8 nor Dell Venue 8 Pro has.
Display and Sound
Given that the same series of Bay Trail processors power all these 8-inch Windows tablets, there aren't many opportunities for companies to differentiate themselves: It's design, display quality and maybe camera performance. Fortunately, Cube didn't skimp on the screen -- the 1,280 x 800 IPS panel here is just lovely. Although it lacks the exceptional clarity you’d expect on small tablets like the Nexus 7, Kindle Fire HDX 7 or the iPad Mini, colors are punchy, without being too saturated, and the screen is easy to view from various angles. Even at only 30% brightness level, the IPS panel can be bright enough for indoor use, so it is quite possible to enjoy the vibrant screen while still getting long battery life.
The speakers are also great, loud and clear enough for watching movies in a quiet room, but you would want to plug in a headphone to get more refined sound for music.
