Pipo S1 RileyROM 1.2
Sorry for the delay but I was trying to find an USB otg cable back here in Portugal, since they are a little bit expensive here..
So I bought one and unfortunately the result is the same...
It looks like the tablet doesn't provide any power to the peripherals..and because of that the device is not recognised.
So I tried with a powered hub and the same happen.. Still without OTG..
Any more ideas?
Originally posted by meks View PostIt looks like the tablet doesn't provide any power to the peripherals..and because of that the device is not recognised.
Any more ideas?
if a common usb mouse will not work, it will be virtually impossible to disassemble and determine the problem and fix it without a great likelihood of doing additional damage. maybe you can find a good used s1 on ****, or elsewhere, for a reasonable price. that may be the only practical approach to get a working usb port.
that's all i can think of tonight, sorry
I'm having an issue with battery on this rom. It charges faster when I use it while it does, it may sound good but it is a "fake" charge because, although it reaches 100%, doesn't last the time it should with a full charge.
When I say fast I mean really, really fast. Fully charged in half an hour or so.
I know the easy solution is not to use it while it charges but it doesn't hurt to ask and you may wanna know about this or maybe others are having the same issue.
Originally posted by julian6732 View PostI'm having an issue with battery on this rom. It charges faster when I use it while it does, it may sound good but it is a "fake" charge because, although it reaches 100%, doesn't last the time it should with a full charge.
I should note that as a lithium battery ages, it still charges from 0 - 100%, but the total capacity keeps decreasing, meaning the running time decreases, eventually becoming just a few minutes. So it is possible that the battery is actually failing, but if not I hope the calibration app will do the trick for you.
Originally posted by voxjazz View PostI installed Battery Calibration (NeMa v 1.2) from Google Play Store and followed the instructions. This solved all of my battery issues with my Pipo.
Is this ROM for both Pipo S1 and Pipo S1 Pro?
Am considering buying an S1 Pro for the kids - seems like a good tablet for £65, and I am very happy with my Pipo M9 Pro... although only because of RileyROM - with stock ROM it was distinctly average!!! Would like to know that there is a RileyROM option on the S1 Pro before buying in case the stock ROM is not good.
Any thoughts on whether the S1 / S1 Pro are good appreciated!
Thanks.
This ROM won't work on the S1 Pro.
Here is the S1 Pro thread:
Randy
Link2sd Problem - SOLVED !
howdy folks !
just wanted to say, on this Pipo S1 i had a problem with the Link2sd app, just thought you'd like to know how it was fixed !
i formatted each of these "class-X" sdcards with MiniTool Partition wizard, each with 3 primary partitions, here are my results:
i used:
4GB Class 4 sdcard = Not Compatible
16GB Class 6 sdcard = Not Compatible
32GB Class 10, UHS-1, sdcard = Fully Working,Formatted as:
All Primary Partitions:
1st - 24GB, FAT32
2nd - 4GB, EXT4
3rd - 1.3GB, Linux Swap
All 4kb Cluster Size for the formats, but Default cluster size for the Linux Swap File and the Link2sd app successfully finds the EXT4 partition, installs the mount script with success and tells you to reboot for the changes to take effect
So only class 10 sdcards work
as this is the only tablet i have, this post might be in the wrong place so i do apologise if it is
I'm totally new to Rockchip flashing and I'm having a helluva time trying to figure out how to get this to work. I've jumped through some hoops and finally got Finless ROM Flash Tool to recognize the tablet in flash mode (had to disable the USB hub since I'm using Windows 8.1). But now when I go to flash, I get this:
22:10:36 090 INFO:Start to run
22:10:36 090 INFO:Start to test device
22:10:41 090 ERROR:TestUnitReady failed,Errcode(-3)
22:10:42 121 INFO:Test device OK
22:10:42 121 INFO:Start to download file
22:10:42 137 INFO: Start to download files to flash,backup offset=0x20000
22:10:42 153 INFO:Flash Start to download file to flash
22:10:42 199 Info:RKA_File_Download start,file=misc,offset=0x2000
22:10:42 278 Info:RKA_File_Download start,file=kernel,offset=0x4000
22:10:47 278 Errorownload kernel file failed,Offset(0),Errcode(-2)
22:10:47 278 Error: Download System file failed
22:10:47 293 ERRORownload file failed
22:10:47 293 ERROR:Image Thread Failed
22:10:47 309 ERROR:Run failed
The above is from the log file. When flashing, even if I try to flash only the recovery, it stops at:
"INFO:Writing data to flash,Size(xxxx)K,Written(53)K"
Always (53)K. Weird.
I've tried 3 different USB cables, including one with an extra long connector. Any ideas on what might be going on? Thank you.
*EDIT*
Found a CWM Recovery from Danyrolux that flashes only the recovery via RKAndroidTool 1.35 and it errors out with the same thing. I've also tried another USB 2.0 port, directly on the motherboard.
*EDIT Again*
Used a 32-Bit Windows 7 based computer and followed the directions more closely. I had to install the driver a bit differently, using the "Have Disk" method but the drivers finally got in, the tool recognizes it and it's flashing right now.Last edited by natenkiki2004; 16 August 2015, 07:24.
There are currently 1527 users online. 1 members and 1526 guests.
