I've tried the trick with connecting the pins 8-9 directly on the NAND chip, and the other trick with connecting T4 and T5 on the board, and I must have followed those guides 50 times now, both using Windows and Linux, connecting with pieces of wire or paperclips, and to no avail.
Only thing I'm getting as a sign of life from it, is a splitsecond of red light at the SPDIF port, when I connect power.
Is this box truly dead?
SOLVED:
I connected it to power while holding a screwdriver connecting the T4 and T5 solderings (I have tried that before), but then I held down the reset button also while powering it up! Used a book to press down on the corner of the board where the reset button is located, to keep it down
