I also noted that while the TCP buffer was increased the maximum I could download using wifi was only 31 Mbps while I could D/L at 54 <Mbps using Ethernet (my maximum). Using Bob (Finless) tweaks for the previous beta I could always get the same speed whether using wifi or ethenet.
Minix X8-H Beta 3 Issues
I could not install the latest Minix Beta 3 FW using the settings in their posted directions. Specifically, Minix states to use "Force Erase All" under configurations when flashing the image. The only way I could get the image to load properly is to use "NORMAL". I believe Bob (Finless) also stated this in his posted notes.
I also noted that while the TCP buffer was increased the maximum I could download using wifi was only 31 Mbps while I could D/L at 54 <Mbps using Ethernet (my maximum). Using Bob (Finless) tweaks for the previous beta I could always get the same speed whether using wifi or ethenet.Tags: None
Originally posted by toymanedk View PostI could not install the latest Minix Beta 3 FW using the settings in their posted directions. Specifically, Minix states to use "Force Erase All" under configurations when flashing the image. The only way I could get the image to load properly is to use "NORMAL". I believe Bob (Finless) also stated this in his posted notes.
May Boot - But Former FW..Not Beta 3
Originally posted by Trhuster View PostI just installed it with "Force Erase All" checked, worked out fine. But wifi is slow for me too. Only around 20Mbps.
The flash tool has a bug with force erase all. It does NOT erase and leaves things behind from the previous ROM.
Just use normal erase and you will be fine.
I am uploading a flashable ZIP format now of beta 3. One that works
Originally posted by toymanedk View PostWhen I used "Forced Erase All" it booted..but it was still the former F/W...the beta3 did not install unless I used "Normal"...I realized this when all my programs and XBMC settings were still from Beta2 using "Forced Erase All". You should have to reenter all your settings again if Beta3 installed fully....otherwise you still will have Beta 2 installed.
Yea if Forced Erase All meaning it will really erase all it does not do that for me. But when check for info in settings/phone it says todays date (beta 3).
Originally posted by Trhuster View PostYea if Forced Erase All meaning it will really erase all it does not do that for me. But when check for info in settings/phone it says todays date (beta 3).
Many folders are setup and created on first boot and not just /data!
/sys is one important one as an example.
There is a reason Minix is releasing these as only .img flash tool ROMs for now. They want it erased and a clean system for testing. If you did not erase and have issues, your not helping Minix but possibly causing confusion for them by possibly reporting bugs that don't exist.
My suggestion would be to reflash and use normal erase.
Originally posted by Finless View PostYes but you have junk left over from beta 2!
It's possible there is more than one version of the flash tool around.
Minix, what version of the flash tool are you using in the lab?
The latest version I got was:
v2.0.0.140306
Originally posted by Finless View PostIt's possible there is more than one version of the flash tool around.
v2.0.0.140306
But one thing i noticed that my A2 airmouse stutter alot when playing video over wifi. When playing same video over ethernet A2 airmouse is normal even when testing jellyfish 70Mbps.
Edit: Noticed that it is alot cooler now, from around 60c to around 40c. Nice!
First Impressions of Beta 3
It took a while to settle down, but once it did, there's a lot to like here: stable, fluid and fast.
On Minix Beta 3, completely stock (and with Bob Finless' TCP/IP tweak incorporated), my Ethernet speed - as measured by Ookla-SpeedTest - can be seen here:
A new record, I think.
- My Antutu score is 21140 - not too shabby, and up by 1200 over Beta 2.
- Minix XBMC runs beautifully, with no A/V sync issues at 1080p (or any other resolution).
Problem with my minix neo x8-H
Hello guys,
I am a new member here , i bought minix neo x8-H 3 days ago and it was working fine but yesterday when i turned it on than it stucks on minix logo loading screen after that nothing sometimes when i turn it on it loads the minix logo loading screen after that screen goes black and nothing after that.So one of my friend advised that installing new rom can solve this problem so i installed Finless bob's x8-H Rom but its still same , it loads up freaky tab finless rom logo after that it goes black screen , never boots up android.
Any help for me?
so has anyone seen any random reboots on beta 3? or am i the only one?
no xposed. ive tried with bobs tweaker, and without. with cpu fix and without and i still see random reboots/.
as an experiment, i flashed the cpu fixer from bobs finless rom 1.0 which basically reverts the kernel back to the may 29th version and i havent seen 1 reboot since. idk.. maybe a beta 4 is in the works from minix..
edit: and hopefully i dont sound frustrated. im not really. its why i love getting into android roms; the freedom, and really is enjoyable to mess around. otherwise i would leave it stock. but a random reboot really grinds my gears!
right now im having good results with the older kernel. till i start messing around again
which reminds me, was thinking of re-downloading the beta and trying to flash again. i cant figure what would make my case special..Last edited by cuezaireekaa; 06-30-2014, 06:01.
Re: Minix X8-H Beta 3 Issues
Any help for me?
Originally posted by cuezaireekaa View Posthave you resolved this? i would suggest a full wipe of data AND media which will wioe internal storage completely, then flash the rom. i noticed that just doing a factory reset in recovery left some things from a previous install
There are currently 1710 users online. 3 members and 1707 guests.
