Trekstor Xintron 10.1 Root
I'm not sure if we can doing anything with it...but thanks for the information.
If you can give me a link to the factory firmware...I can make you a rooted ROM.Randy
Originally posted by rrileypm View PostI'm not sure if we can doing anything with it...but thanks for the information.
Ok I'll try to search it, meanwhile I got this update file avaible, don't know if can be useful: http://www.mediafire.com/download/dv...ateXintron.zip
Sadly I can't use adb cause the device didnt get recognized:
That's not a whole firmware...just the addition of some apps and a couple of patches.Randy
Yes...they can be useful.
The files I MUST have are:
parameter
misc.img
boot.img
recovery.img
system.img
You can also download one of my ROM kits and use the ROM dump tool from Windows. Instructions are provided in the folder.Randy
Oh, and I also need kernel.imgRandy
I really don't need the file, but I do need to know which loader.bin version they are using. If you can dump it, also include it. Just zip the contents and uploaded to Dropbox, or Google Drive or some other cloud storage and send me a share link. You can PM it to me, if you want.Randy
Originally posted by rrileypm View PostI really don't need the file, but I do need to know which loader.bin version they are using. If you can dump it, also include it. Just zip the contents and uploaded to Dropbox, or Google Drive or some other cloud storage and send me a share link. You can PM it to me, if you want.
RK tool 2.1 didn't recognize the device, the file i linked its the folder that i was able to pull with adb command, i'm working to find a way to get the others
I just dump using the DD command in busybox and dump to SDcard.
dd if=/dev/block/mtdblock1 of=/sdcard/kernel.img
dd if=/dev/block/mtdblock8 of=/sdcard/system.img
dd if=/dev/block/mtdblock2 of=/sdcard/boot.img
dd if=/dev/block/mtdblock3 of=/sdcard/recovery.img
Check your MTD blocks for the same number but most have been the same.Randy
Originally posted by Glace View Posthttps://www.dropbox.com/s/oxuxczh1cy...%20Xintron.zip
In the RK tool, you need to be in flash mode with USB debugging turned off. If the drivers are installed, you should see the tablet recognized as a mass storage device...click the "switch" button to reboot to flash mode. You can then follow Finless Bob's instructions.
The dd command above will work for the major partitions, but I can't do a ROM without the parameter file...and I have to know which loader version is installed.
Are we doing a JB ROM or a KK ROM?Randy
Originally posted by rrileypm View PostI just dump using the DD command in busybox and dump to SDcard.
The problem is that i get the follow message when i try to run this command:
dd if=/dev/blk/mmcblock1 of=/sdcard/kernel.img
/dev/blk/mmcblock1: cannot open for read: No such file or directory
I'm doing this from adb shell but from pc not directly from tablet cause is only partially rooted by trekstor
Again thanks for your help
Edit: Android JB 4.2.2, bootloader Droiboot v. 2.0, recovery Android System Recovery <3e>
Edit 2: I got these but i'm not sure they're correct
Thanks...I'll take a look at them. If you can do the system.img the same way it would be great.Randy
I've checked the contents of these files, and they are blank.Randy
There are currently 2730 users online. 0 members and 2730 guests.
