root 4.0.4 aml8726-mx
    hello
    i searched the whole net for root solution to this device
    unfortunately nothing work z4root crystal root utoo root
    nothing helped .
    boot log
    Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.
    Firmware
    i will be grateful if someone can provide root or custom recovery
    best regards
    Can you post a picture of this device?
    There is plenty of rooted firmware for the amlogic 8726 chipset
    Originally posted by bogyman View Post
    hello
    nothing helped .
    boot log
    Firmware
    best regards
      its sattelite box with ics 4.0.4 , every time i try to root via recovery .
      its shows " E: verfcation failed ..... "
      i am desparted , i hope above Firmware + log can help
      1. U-Boot 2010.06-svn5644(m3_mbox@trunk) (Feb 20 2014 - 09:36:58)
        Machine: AMLOGIC MESON3 8726M SKT SH
        Linux version 2.6.34-svn6577 (release@androidser2) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-202)
      1. 0x000000800000-0x000001800000 : "aml_logo"
      2. 0x000001800000-0x000002800000 : "recovery"
      3. 0x000002800000-0x000003c00000 : "boot"
      4. 0x000003c00000-0x000023e00000 : "system"
      5. NAND bbt detect factory Bad block at 5a00000
      6. 0x000023e00000-0x000025e00000 : "hide"
      7. 0x000025e00000-0x000031e00000 : "cache"
      8. 0x000031e00000-0x000051e00000 : "userdata"
      9. 0x000051e00000-0x000100000000 : "NFTL_Part"
      specs
        post a link to the satellite box this goes on.
        also you haven't said why you need it rooted.
        there may be a work around for what you are trying to do.
        EDIT: added the link below
        Code:
        TUTORIAL PROCESSO ROOT NO ANDROID DO AZBOX TITAN
        https://www.facebook.com/azboxtitan/posts/1438163536396224
