I'm providing five options:
Minix Neo X7 - https://drive.google.com/file/d/0B99...npXdTZYUjhOX1U
PQ Labs A350-SSD - https://drive.google.com/file/d/0B99...TJXM2VZaGtMT2c
Radxa Rock - https://drive.google.com/file/d/0B99...GNUakZFenNLRVU
Rikomagic MK802IV New (AP6210) - https://drive.google.com/file/d/0B99...mIyLTl4Z3ZFRmc
Rikomagic MK802IV Old (8188EU) - https://drive.google.com/file/d/0B99...jVGRG14aGVoLVE
Just a reminder that the Linuxium user password is 'p' (without the quotes) and that a root password can be set by entering 'sudo su -' and then 'passwd root' in a terminal window. You can expand the file system to utilise the whole SD card by entering 'echo -e "d\nn\np\n1\n81921\n\nw" | sudo fdisk /dev/mmcblk0' then rebooting and entering 'sudo reseize2fs /dev/mmcblk0p1' to complete the resizing and Mali hardware acceleration can be enabled by entering 'sudo mv /usr/lib/arm-linux-gnueabihf/mesa-egl /usr/lib/arm-linux-gnueabihf/xmesa-egl'.
Enjoy!
(see also https://plus.google.com/109451178006...ts/P6TNn3sisa2)
