i have just been bought a arnova 10-g2 and are new to this.
i have obtained a 32g micro sd card so i can transfer some films to the card.
when i power the arnova on i have a widget saying video clik on this and i only get what films
are in the internal memory.
how do i get the films to list on my 32g card?
all now ok.
the arnova 10g2 user guide is useless.
another problem? I show 19g free memory on sd card but while trying to move a 4g MKV file
it comes up with Not Enough memory?
SDcard is formatted FAT32. Fast 32 cannot handle files larger than 4GB. Thats the way it is.
The gingerbread kernel and system does not support NTFS. I have some .ko files that will add NTFS but it will be a pain to use for SDcard as you have to manually mount it using a mount manager app.
