Netflix OS API level
    Those who are using Netflix on S89/S89-H, can you please check settings under Netflix and confirm what OS API it is showing?
    Minix x8/x8-H shows it as 15. It should be 19 for kit kat.
    I am just trying to figure out if it is Amlogic issue or Minix issue.
    To go to Netflix settings, you need to click on 3 dots on right top corner. You will see settings and Logout option. In settings, you can see Netflix version, build details and OS API.
    ~Gopichand Pai
    No one?
    ~Gopichand Pai
      Originally posted by gopichandpai View Post
      No one?
      Its API 15 on beelink m8/s 82
        Thanks. Seems like it is Amlogic issue then.
        ~Gopichand Pai
          xbmc report api 19 even though on square m8 Netflix shows api 15
          JustMe
          Bugs are Sons of Glitches!
          JustMe
            Tronsmart S89-H api 15
              Apk's are compile with a minimum SDK level and a maximum level, for reaching a wider range of devices.
              Do you have a device with a different SoC to compare ?
              Probably it's also api 15, if that's the case them it's not an AML thing.
              Netflix probably needs to update some service, or can't make it compatible with an higher api.
              Tapatalked
              if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
              then mv $user.contact.up.post /.trash; set response($response.type = ignore);
              $user.up.post.ignore_in_future = true; fi;
                My other devices on Kitkat show Api level 19.
                ~Gopichand Pai
                  Then it seems that AML is using some backwards service to be able to run Netflix, or the service it requires.
                  Tapatalked
                    anyone tried new netflix
                    netflix 3.6.3 build 1631cnntv under 1 week old
                    Still shows api 15
                    Justme
                    JustMe
                      Yes, for me too it shows 15. Looks like AML has to fix something so that Netflix can consider the API 19.
                      ~Gopichand Pai
                        maybe someone should show this email to amlogic
                        JustMe
                        JustMe
