Thx for the forum, Bob:] (Steal ROM anytime soon?)
    Can you tell if i am rooted. I used Superoneclick which seemed to work. If I run it again, it does say that device has been rooted. Curious because none of my info in the command prompt indicates rooting.
      Very odd... there is no mtd folder...
      BUt you can see you blocks now. I just cant see a way to determine wich block is update.img
      We know its not 5, 6, ot 7
      5 = system
      6 = data
      7 = cache
      I am going to guess its block #4. So the command to dump for you will be
      /data/rkdump /dev/block/mmcblk0p4 /sdcard/update.img
      No I cannot tell you are rooted. One problem is when I had you type su (which means super user) it came back with a user root unknown error. I have no idea why.
        Did it work?
        [IMG][/IMG]
        Lord, Ematic makes it difficult!!!
          try using backup.img instead of update.img
          also because direcytory is odd try /mmmcblk0p4
          an extra m
            [IMG][/IMG]
              try backup.img without the extra m in the mmc
                [IMG][/IMG]
                  well I dunno man. we cant seem to get the names beause you do not have mtd
                  lets see you you can dump system so we know weher doing something right
                  /data/rkdump /dev/block/mmcblk0p5 /sdcard/system.img
                  or just try
                    FYI per your partition table here are your blocks
                    [IMG][/IMG]
                      Even i can tell this did not work. Why do you think i dont have mtd and what exactly is it. I'm guessing it stands for mounted. Is not having it some kind of security thing from Ematic?
                      [IMG][/IMG]
                        The only other way I know how to dump a tablet is from linux. Can you setup a dual boot of ubuntu?
                          Never mind.,...... same approcah we are trying but you might have a go anyway.,
                            I'm actually up for anything at this point, but... not today. This crap is giving me a headache. I like learning new things so i'll just think of it as continuing education. How can I contact you when i'm ready to give the Linux thing a go?
                              Hiya Bob, I'm back and this time i have a dual boot with Ubuntu ready. Any time your in the mood to try again let me know. Ill watch for you in my email
                              Kent
                                You're gonna love this, Bob. Ematic emailed me finally and claim I may have a 'defective' device. They are going to replace it. I'll see how the new one works and let you know.
                                Regards, Kent
