M8 Crashes on Video Play
    my M8 Box keeps crashing my video player app after several hours of playing some videos in a playlist without any pause (just playing one by one).
    logcat just tells me that my Proccess has died. nothing more. the previous errors are different every crash.
    here are 2 example logs:
    Code:
    I/AmlogicPlayer(  119): media.amplayer.osd2xenable is not setting,use default false
    V/AmlogicPlayerDataSouceProtocol(  119): L54
    V/AmlogicPlayer(  119): set_cpu_freq_scaling_based_auido failed
    V/MediaPlayerService(  119): Client(322) destructor pid = 1859
    V/AudioSink(  119): close
    V/MediaPlayerService(  119): disconnect(322) from pid 1859
    F/Looper  ( 1859): Could not create wake pipe.  errno=24
    I/AndroidRuntime( 8984): VM exiting with result code 0, cleanup skipped.
    W/InputDispatcher(  517): channel '41e60b58  (server)' ~ Consumer closed input channel or an error occurred.  events=0x9
    E/InputDispatcher(  517): channel '41e60b58  (server)' ~ Channel is unrecoverably broken and will be disposed!
    W/InputDispatcher(  517): Attempted to unregister already unregistered input channel '41e60b58  (server)'
    V/AudioFlinger(  119): removeTracks_l removing track on session 212
    V/AudioFlinger(  119): remove track (4097) and delete from mixer
    V/AudioFlinger(  119): acquireWakeLock_l() AudioOut_8 status 0
    I/ActivityManager(  517): Process com.amlogic.SubTitleService (pid 8984) has died.
    W/ActivityManager(  517): Scheduling restart of crashed service com.amlogic.SubTitleService/.SubTitleService in 0ms
    I/WindowState(  517): WIN DEATH: Window{41e60b58 u0 com.amlogic.SubTitleService}
    D/ActivityManager(  517): send app_CRASH broadcast, packageName:com.amlogic.SubTitleService
    I/ActivityManager(  517): Start proc com.amlogic.SubTitleService for restart com.amlogic.SubTitleService: pid=9035 uid=1000 gids={41000, 3003, 1028, 1015, 3002, 3001}
    W/ContextImpl(  517): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1154 com.android.server.am.ActivityManagerService.onVideoPlayerCrashed:3688 com.android.server.am.ActivityManagerService.handleAppDiedLocked:3718 com.android.server.am.ActivityManagerService.appDiedLocked:3856 com.android.server.am.ActivityManagerService$AppDeathRecipient.binderDied:1043
    D/IPReset (  826): called
    D/dalvikvm(  117): GC_EXPLICIT freed 43K, 2% free 6310K/6392K, paused 1ms+2ms, total 45ms
    W/InputDispatcher(  517): channel '41eddd38 eicin.TemplatePlayer/eicin.TemplatePlayer.TemplateActivity (server)' ~ Consumer closed input channel or an error occurred.  events=0x9
    E/InputDispatcher(  517): channel '41eddd38 eicin.TemplatePlayer/eicin.TemplatePlayer.TemplateActivity (server)' ~ Channel is unrecoverably broken and will be disposed!
    D/ActivityManager(  517): send app_CRASH broadcast, packageName:eicin.TemplatePlayer
    W/InputDispatcher(  517): Attempted to unregister already unregistered input channel '41eddd38 eicin.TemplatePlayer/eicin.TemplatePlayer.TemplateActivity (server)'
    I/ActivityManager(  517): Process eicin.TemplatePlayer (pid 1859) has died.
    I/WindowState(  517): WIN DEATH: Window{41eddd38 u0 eicin.TemplatePlayer/eicin.TemplatePlayer.TemplateActivity}
    W/WindowManager(  517): Force-removing child win Window{4203aef8 u0 SurfaceView} from container Window{41eddd38 u0 eicin.TemplatePlayer/eicin.TemplatePlayer.TemplateActivity}
    W/ActivityManager(  517): Force removing ActivityRecord{420323c0 u0 eicin.TemplatePlayer/.TemplateActivity t3}: app died, no saved state
    D/Zygote  (  117): Process 1859 terminated by signal (6)
    Code:
    I/DEBUG   (  123):     4013916c 1c43e914 d11e4607 f9c4f001 29046801
    I/ActivityManager(  506): Start proc com.amlogic.SubTitleService for service com.amlogic.SubTitleService/.SubTitleService: pid=6579 uid=1000 gids={41000, 3003, 1028, 1015, 3002, 3001}
    D/dalvikvm( 6579): GC_CONCURRENT freed 202K, 25% free 704K/936K, paused 1ms+0ms, total 3ms
    D/dalvikvm( 6579): GC_CONCURRENT freed 162K, 18% free 928K/1120K, paused 1ms+0ms, total 5ms
    D/dalvikvm( 6579): GC_CONCURRENT freed 208K, 18% free 1106K/1348K, paused 2ms+0ms, total 6ms
    D/TextLayoutCache( 6579): Using debug level = 0 - Debug Enabled = 0
    E/sub_jni ( 6579): ================= JNI_OnLoad ================
    I/sub_jni ( 6579): [subtitle_thread:479]starting controler thread!!
    I/sub_subtitle( 6579): ----------------------close_subtitle------------------------------
    I/sub_pgs ( 6579): init pgs_subtitle info
    I/sub_dvb ( 6579): [dvbsub_init_decoder::413] Invalid extradata, subtitle streams may be combined!
    I/sub_jni ( 6579): [inter_subtitle_parser]get_subtitle_num():0
    E/NativeCrashListener(  506): Exception dealing with report
    E/NativeCrashListener(  506): libcore.io.ErrnoException: read failed: EAGAIN (Try again)
    E/NativeCrashListener(  506):     at libcore.io.Posix.readBytes(Native Method)
    E/NativeCrashListener(  506):     at libcore.io.Posix.read(Posix.java:128)
    E/NativeCrashListener(  506):     at libcore.io.BlockGuardOs.read(BlockGuardOs.java:149)
    E/NativeCrashListener(  506):     at com.android.server.am.NativeCrashListener.consumeNativeCrashData(NativeCrashListener.java:240)
    E/NativeCrashListener(  506):     at com.android.server.am.NativeCrashListener.run(NativeCrashListener.java:138)
    D/ActivityManager(  506): send app_CRASH broadcast, packageName:eicin.TemplatePlayer
    D/Zygote  (  125): Process 1793 terminated by signal (6)
    I/ActivityManager(  506): Process eicin.TemplatePlayer (pid 1793) has died.
    I/WindowState(  506): WIN DEATH: Window{41a53718 u0 eicin.TemplatePlayer/eicin.TemplatePlayer.TemplateActivity}
    W/ContextImpl(  506): Calling a method in the system process without a qualified user: android.app.ContextImpl.sendBroadcast:1162 com.android.server.am.ActivityManagerService.onVideoPlayerCrashed:3689 com.android.server.am.ActivityManagerService.handleAppDiedLocked:3719 com.android.server.am.ActivityManagerService.appDiedLocked:3857 com.android.server.am.ActivityManagerService$AppDeathRecipient.binderDied:1043
    W/ActivityManager(  506): Force removing ActivityRecord{419fa268 u0 eicin.TemplatePlayer/.TemplateActivity t4}: app died, no saved state
    W/WindowManager(  506): Force-removing child win Window{41a06e68 u0 SurfaceView} from container Window{41a53718 u0 eicin.TemplatePlayer/eicin.TemplatePlayer.TemplateActivity}
    E/InputDispatcher(  506): Received spurious receive callback for unknown input channel.  fd=178, events=0x9
    this problem occours on finless rom 1.3beta aswell as on the new 1.7 rom.
    seems to be a hardware bug. i cant see any other reason this will happen.
    have you any ideas?
    no ideas?
    did no one play videos over hours in a loop?
      Did you tried other apps? Maybe you have memory leak in your app?
        I could not found any memory leaks on my app during a lot of debugging work.
        my rom has no other apps than this, but i will try to install one.
        so none of you guys ever tried to let the m8 run with videos over servall hours?
          Yes I do run 3-4 hours daily without any problem but using old Lifeforce Rom....
            im afraid its not about playing 3-4 hours but 10-15 hours sometimes it lasts even 24 hours before it crashes.
              Ok got it you are doing extreme Crash test cos in real life who plays 15hours non stop
                Well..
                Perhaps.. you should at a time-out between vids, giving xbmc time to emty the cache...ect
                But,
                I think you are better off.. buying a cheap videoplayer..
                -i donated a bunch of these.. to the public musea
                And as test a androidbox with trackball... to run a website.. nijntje/miffy where kids can play games..
                Anyway.. just my 2cents
