702c home button
702c home button
The home soft key doesn't work. It did until I downloaded a couple of Bible Apps from Amazon. I unistalled them the soft button still doesn't work. Also the large physical button has never done anything. Its really frustrating to use the back key several times to get to the home page. All the other soft keys work fine. I reset it with the recessed button on the back. HELPTags: None
Can't give a simple option
Originally posted by donschaffer View PostThe home soft key doesn't work. It did until I downloaded a couple of Bible Apps from Amazon. I unistalled them the soft button still doesn't work. Also the large physical button has never done anything. Its really frustrating to use the back key several times to get to the home page. All the other soft keys work fine. I reset it with the recessed button on the back. HELP
I am not sure exactly what manages to get corrupted, and not sure what to search for. There is the possibility it is more related to the Android OS on the tablets than with the tablets themselves. I do know that the hardware buttons use a resistor network into a A to D converter as the way they determine which key is pressed, I would guess because that way they only need one line into the processor instead of 5, but presumeably that shouldnt have anything to do with the current problem since you are talking about the soft keys.
Guess I am lucky cuz I downloaded some Bible Apps and so far my keys and all work okay. I didn't get them from Amazon so maybe I'm either lucky or maybe not getting them from Amazon is the key.
Sent from my Polaroid PMID701i using Tapatalk 2Tablets: Polaroid PMID 701i, PMID 4311, Zeki 10" tablet
"God Loves You"- Arlo Guthrie
There are currently 2719 users online. 1 members and 2718 guests.
